01-15-2021, 03:31 PM | #1 |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
Bigger tires on 1LE rims
Does anyone have any experience with 315, or bigger, tires on stock 1LE wheels? When I get to the end of my warranty and wear out my current set of tires I'm thinking of going with a supercharger and putting bigger rubber out back.
01-15-2021, 05:51 PM | #2 |
Drives: 2020 2SS 1LE Join Date: Jun 2011
I have been thinking the same, but more for daily use. I have heard of people going 295/315's with Michelin's but I think that was more because that tire runs a little narrower than the OE GY's.
I believe I have seen some 325's on the back without major mods other that moving that wiring harness on the drive rear. |
01-15-2021, 07:18 PM | #3 |
I did that back in 2017. Did the 295/335s on my 2017 1LE.
01-16-2021, 11:28 AM | #4 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
You can mount 315s on the 11" rears. That is within the rim width recommendations of the tire manufacturers. The problem isn't the width (315) - the problem is that there are very few options in 315/30/20 size. There are lots in 315/35/20, but those are 1.5" taller than the OE 1LE tires and that's a bad idea for a lot of reasons. You'll hurt performance in lateral grip, braking, and acceleration with those tires. You'd be far better off to stay with the stock 305/30/20.
Matt Miller
2020 SS 1LE |
01-16-2021, 11:32 AM | #5 |
Yes, 305/325ZR30-19 is stock here.
'20 ZL1 1LE A10,
01-16-2021, 02:18 PM | #6 | |
01-16-2021, 02:30 PM | #7 |
I have 315/30/20s in the rear on 1LE replica wheels, same 43mm offset as OEM. No problems whatsoever (the driver side body harness is relocated)
01-16-2021, 05:25 PM | #8 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
That looks really good
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
01-17-2021, 02:24 AM | #9 |
335s on the 1le factory wheels
01-19-2021, 08:21 AM | #10 |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
335/30...without a spacer?
