08-17-2018, 05:36 PM | #1 |
Drives: 2017 Camaro 2SS, MRC, NPP, Join Date: Jul 2016
A8 shudder or something else?
Well I thought I had the shudder issue. Slight rumble vibration 8/7 gear, for a few weeks. Earlier this week, the car started doing it more often and much more harsh. Today I had noticed that it was doing the shudder thing outside of 8/7 gear and it would also do it in manual mode. I was under the impression that if I was in manual mode the shudder should not exist.
Any ideas? I called my local dealer who told me to call back after next week since their trans guy is on vacation and the car will just sit Last edited by zirad54; 08-17-2018 at 08:24 PM. Reason: Correction |
08-18-2018, 04:42 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: May 2016
Definitely sounds like the TC shudder issue...it does get worse over time...got the triple flush done on two occations..it helped but shudder is still there...they are now replacing the TC
08-19-2018, 07:30 AM | #3 | |
Drives: 2017 2SS Auto Join Date: Apr 2017
Yup that’s the TC issue. Manual mode didn’t make a difference for me either towards the end. Only time it didn’t shudder was during hard acceleration. Be aware that the flush probably won’t work permanently if you waited this long. |
08-19-2018, 07:35 AM | #4 |
Drives: 2016 Z06 coupe Join Date: Dec 2016
Mine gos in tomorrow for the tranny fluid change.
08-19-2018, 07:52 AM | #5 |
Drives: 2019 1SS M6 Join Date: Jun 2018
I had my TC replaced last week (1300 miles) ... noticed a shutter and took it to the dealer, they replaced the torque converter without hesitation (It was nasty AF inside).
08-19-2018, 10:14 AM | #6 |
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
Had mine done last week with 3K on the clock. I took a copy of the TSB in with me, and good thing I did, they had never heard of it and mine with the first they had in for the shudder issue. They did of course further investigate the TSB on their end and did the flush and changed the filter too. Hopefully, got to mine soon enough, if I didn't see the TSB on the forum. I probably wouldn't have noticed it so early.
Current: 2018 ZL1 ZLE
Memories: 2017 50th Anniversary Camaro Convertible (Sold) 2003 Dodge Viper (Sold) 2005 Lingenfelter Corvette (Sold) 2004 Mazda RX-8 (Sold) |
08-19-2018, 10:18 AM | #7 | |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
Mine has same issue as you. Like a rumble vibration around 50mph or so when i press on it just a bit. Same in Manual mode on the HWY that is... I will bring mine back in as well within a week or so and leave my outcome here for others to know. |
08-19-2018, 12:43 PM | #8 |
Howdy! Pete here...
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC Join Date: Jul 2009
I had the triple tranny flush at about 10 K miles. That seemed to cure the issue for about 20k rumble-free miles. Now it's back at 31k miles. It's going into the service department on Monday morning. Hopefully I will get a torque converter replacement.
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie! ___________________________________________ ___________________________________________ Ordered from GM Delivered to dealership and home 9-16-16 This car is a beast! |
08-19-2018, 09:01 PM | #9 |
Mine felt the same way ... 50 MPH at about 1k RPM and it was noticeable.
08-20-2018, 12:47 PM | #10 | |
Howdy! Pete here...
Will update here when I know more, but pretty sure this is the OP’s issue, from the description of symptoms. Hopefully, reporting the progress on my car will help inform a way forward. By the way, mine does the rumble in manual mode, too. Cheers!
PnCRedJwl2SS
08-26-2018, 01:44 PM | #11 |
Drives: 2016 Camaro 2SS/RS Join Date: Oct 2008
TC replacement wasn't a permanent solution either. Mine was replaced last year, and has already started with the same symptoms right before the shudder.
2016 2SS: Silver Ice, A8 Auto, Adrenaline Red, Black Rally Stripes, and Black bowties.
My Journey..... 1100 Status - 08/17/2015 : 2000 Status - 09/28/2015 2500 Status - 09/29/2015 : 3000 Status - 09/29/2015 3000 Status - 10/19/2015 TPW 11/9 3800 Status - 11/04/2015 Seq: 122808 4300 Status - 12/17/2015 (Charlotte, MI) 4200 Status - 01/08/2016 4800 Status - 01/14/2016 5000 Status - 01/19/2016 6000 Status - 01/20/2016 |
09-03-2018, 05:37 PM | #12 | |
Howdy! Pete here...
Stay tuned...
PnCRedJwl2SS
09-03-2018, 06:52 PM | #13 |
Drives: 2016 Blue 2SS Join Date: Mar 2016
I get a rumble strip type shudder at 50-70 MPH, if I ask to have this problem addressed, is this an appointment in which they have to keep the car or can this be done same day typically?
09-03-2018, 07:37 PM | #14 | |
Howdy! Pete here...
My TC replacement took a week and it took them 2 days to get the part in first. Hope that helps...
PnCRedJwl2SS
