05-07-2018, 12:26 PM | #1 |
Drives: 2018 ZL1 Convertible Join Date: Nov 2011
Bigger Guy - Smaller ZL1 Seat - TOO TIGHT
Any 'bigger people' on here what have a difficult time fitting comfortably in the 2017-18 ZL1 seat? Any fixes you have found? Thanks . . . .
05-07-2018, 12:41 PM | #2 |
Keto diet worked well for me...
05-07-2018, 12:43 PM | #3 |
05-07-2018, 01:03 PM | #4 |
Drives: 2017 NFG ZL1 6SM Join Date: Dec 2016
I am 6'7", 285lbs. It is no SRT seat, but it is ok for city cruising.
05-07-2018, 01:08 PM | #5 |
Is there a way to adjust the bolsters OUT on these things? They're tight on my legs/back, my knees have to be pushed together or the bolster presses firmly on my thighs. I'm not fat/over weight, I'm just wider/bulkier...The Recaro's in the CTS-V3 and ATS-V are adjustable in every direction.
05-08-2018, 10:13 AM | #6 |
Drives: '18 RH ZL1 1LE Join Date: Apr 2018
6'3" 29x lbs (down from 365 in aug1 and still dropping)
Seats fit great for me. I like to set the seat all the way back and recline as far as possible. Then I ratchet the belt tight and set my driving position. Poor man s harness! |
05-08-2018, 11:41 AM | #7 | |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
I'm 5'10" roughly 260 and have problems if the door isn't open all the way and the seats aren't in the exit position. As far as sitting in the seats, snuck as a bug.......... |
05-08-2018, 11:43 AM | #8 | |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
There may be a way to put the seat back frame and bottom frame from an SS in the seat which has wider bolsters while keeping the Recaro padding. The Recaro frames could be heated and possibly widened a little too. Neither are easy fixes, but I hate being uncomfortable in a car seat too. |
05-08-2018, 12:02 PM | #9 |
Thank you Al Oppenheiser!
05-08-2018, 01:01 PM | #10 |
If I were to bolt in 'another seat' regardless of the seat's source, I wonder how the car will react to having the electrical connection to the seat disconnected. There are air bag connections, seat heater connections, seat ventilation connections, seat adjuster connections, etc . . . .
05-08-2018, 01:21 PM | #11 | |
I use my A Pillar to suspend myself using my left hand, while I squeeze myself in, feet first. |
05-08-2018, 02:03 PM | #12 |
Dyno Show Queen LOL
you get used to it... and going on my ss i feel like i sit low now lol.
05-08-2018, 06:20 PM | #13 |
I had to cancel an order on a Z/28 over the seats. Lost over 100 lbs "keto" and seats fit perfect now.
The ZL1 seats are also a bit wider than the bolsters on the Z/28 too. The way prices went on the Z/28 being over weight was a good thing for once. 5th Gen ZL1 seats are awesome for the big guys. |
05-08-2018, 07:23 PM | #14 |
Drives: 2017 ZL1 silver A10 Join Date: Jul 2017
I called a auto interior company and they suggested pulling padding out on the sides and adding a little to the middle. I might try it and let you know. It seems like bending the frame out would work the best though.
Thread Tools | |
