Old 04-10-2023, 02:08 PM   #1
JBinSD
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT
LT-1 Questions from former SS owner
Hey guys. I had a '16 2SS and recently bought a '23 LT-1. I love the V-8 and 6 MT with a droptop.
I do have some Q's:
1. Why did they change the shift pattern on the LT-1? Isn't this the same Tremac 6060?
2. The interior plastics feels thinner/cheaper than my 2SS. Can I use the leather SS kneepads in the LT1? I already have the Recaro seats.
3. '23 LT1 transmission requires both the clutch and the brake depressed to start the ignition. My '16 only needed the clutch. This is a safety hazard if stalled while moving (did this yesterday.) Is there a way to bypass the brake requirement?
4. Skip-shift for 1-2 shifts; is the little dongle-thing from Gen5 (or other source) still the solution? The intervention seems inconsistent; sometimes it blocks, sometimes it doesn't, so its gotta go.
5. No track mode option. My 2ss had MPP and MRC. The LT1 only has MPP. I assume nothing changes in the suspension between touring and sport if no MRC? The exhaust is definitely louder :-) in sport.
6. LT1 engine bay looks kinda empty without the extra cooling systems; guess there's not much to do about that.
7. Android Auto is now wireless. That is a nice touch from the '16. I still should probably charge in the car, is the console the best USB source to charge?
Any other solutions or changes to improve the LT1 suggested? I know the 245's aren't enough rubber for the V-8. I leased the car for 2 years to make sure I still want it and will buy at the end if I do. This prevents an immediate tire change unless I find some 1LE's for a deal.
Cheers for any advice or suggestions.
Joel
JBinSD is offline   Reply With Quote
Old 04-10-2023, 02:27 PM   #2
MadeInHB
Drives: 2023 Camaro 2SS
Sent from my iPhone using Tapatalk Pro
MadeInHB is offline   Reply With Quote
Old 04-10-2023, 02:37 PM   #3
FarmerFran
FarmerFran's Avatar
1. No clue, both my 2020 2SS and 2023 ZL1 R is up right
2. Yes
3. Been like that since 19
4. Skip shift eliminator
5. Correct. Only steering and sound
6. Get a supercharger
7. I plug mine in under armrest
8. Have fun
2023 Camaro ZL1 Vert TR-6060 Sharkskin "Sharky"
Firecracker Red Wrangler Willys, 3.6L eTorque, 850RE 8 speed automatic, 25W Willys package, Technology Group, Convenience Group (aka $600 garage door opener), Cold weather Group, Trailer Tow and HD electric group with AUX switches, 3 piece black freedom top.
Old 04-10-2023, 02:41 PM   #4
JBinSD
I have never been able to figure out how to post a pick correctly in this forum, lol.
Old 04-10-2023, 02:46 PM   #5
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Turn your phone 180 degrees.
Or use MS Paint and rotate the image 180 degrees and resave the picture
For all intent and purpose LT1's are V6 bodies with V8 engines under the hood.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
Old 04-10-2023, 02:51 PM   #6
JBinSD
the images have normal orientation on my phone and computer; they only flip when posted here.
As far as I understand it, there is no "V-6" body, they are all the alpha platform; it's just the front end that varies based on the trim level.
Old 04-10-2023, 02:57 PM   #7
FlukeSS
FlukeSS's Avatar
Pretty much every feature you had on your 2SS 1LE the V6's do not get same with the LT1. Including some aspects of 1LE package, coolers, drive modes, etc.
LT1's are lighter weight, better for drag racing, but get heat soaked faster.
Old 04-10-2023, 03:06 PM   #8
Junction65
Junction65's Avatar
Drives: 2011 GMC Sierra 1500
^This
2023 LT1 Coupe M6 - Black (GBA) on Black (H1T)
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W)
LT1 PBC engine built by Shane Parker
Current mileage: 310
Junction65 is offline   Reply With Quote
Old 04-10-2023, 10:02 PM   #9
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Congratulations, enjoy your Car
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
Old 04-11-2023, 08:46 AM   #10
ember1205
Hot Camaro
ember1205's Avatar
V6? Are you thinking of the 1LT trim level?
Old 04-11-2023, 10:40 AM   #11
Zr8000
Drives: Chevy Camaro
The easiest way to save 3k on a car is to do everything you are asking about that is different from your old ss. Why they even made the lt1 trim level is beyond me
Zr8000 is offline   Reply With Quote
Old 04-11-2023, 12:15 PM   #12
Casper the friendly G
Drives: 17' Chevy Kamaro SS 6 speed
Yeh..if his shift pattern change I bet he got the V6 and GM mistakenly put LT1 badges instead of 1LT badging.
Casper the friendly G is offline   Reply With Quote
Old 04-11-2023, 12:20 PM   #13
ember1205
Hot Camaro
ember1205's Avatar
Is there badging for 1LT?
Old 04-11-2023, 01:58 PM   #14
JBinSD
haha, trust me, I'd know if I was missing a few cylinders. The LT-1 is a V-8, but the shifter (red, like the SS's) has Reverse up and right (instead of up and left like the SS's.) I have no idea why the shift pattern is different on the LT-1.
