03-04-2023, 11:07 AM | #1 |
Very little sound coming from subwoofer?
All of the sudden I'm getting very little sound from my subwoofer. If I put my hand on it, there's a little bit of vibration coming from the speaker. I checked all of the connections at the amplifier, and all of the connections inside the sub enclosure, and everything seems tight. What else do I need to check?
RUXIFEY Smoked LED Side Marker Lights / Black SS emblem on rear bumper / Blue SS vinyl overlay on front bumper emblem / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint RE Audio RFX10D4 10" Sub / Hand-made sub enclosure / Hifonics Zeus ZRX1200.1D amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
03-04-2023, 02:55 PM | #2 |
Drives: Chevy Camaro Join Date: Apr 2020
Fuses in the amp. If those are good and you have good signal to the amp, either the amp failed or the sub burnt a voice coil.
03-04-2023, 04:04 PM | #3 |
I checked the fuse on the amp, and it was intact. The letters on top of the amp light up, and they're still lit. Guess maybe I need a stereo place to look at it.
03-05-2023, 01:14 PM | #4 |
disconnect one of the speaker connections and put a meter across the subwoofer terminals. Use the lowest ohm setting. You should get either 2 or 4 ohms (approximately) depending on the impedance of your sub.
The low output sounds like a major malfunction. Speaker voice coil more likely to go than amp. |
03-05-2023, 04:38 PM | #5 |
I put a multimeter on the speakers, number was right (right around 4 ohms for a 4 ohm speaker). I put a 9 volt battery on the speaker inputs, and got the scratchy sound which indicates the speaker is still good. I noticed that the power light wasn't coming on at the amp, even though the color lights on top were turning on. I put the multimeter on the power & ground inputs on the amp - and it read 5.5 volts (should be at least 11 volts, for anyone interested or facing the same issue). Battery measured 12+ volts, and it reads 14+ volts on the dash while running. Weird. The amp & power cable fuses were both good. I decided to loosen the ground cable, wiggle the connection, and tighten it back down. I guess that was the ticket, it now works great again.
03-06-2023, 07:18 AM | #6 |
You could try a little anti-corrosion gel on that ground area:
https://www.amazon.com/Super-Lube-82...s%2C299&sr=8-2 |
03-06-2023, 10:14 AM | #7 |
Thanks, I bookmarked it. I don't think anything is corroded, if anything maybe I should have sanded the area a little. It's only been hooked up a couple of months. It's grounded with my line out converter.
03-06-2023, 10:37 AM | #8 |
Electrical Engineer
You need more contact area for that ground, and to bare metal and not painted metal. You could get a grounding washer (the spikey kind) and keep the amp ring lower than that control wire ground.
I typically use masking tape to identify the contact area of the amp ground ring, then remove paint for that area only. You need a low-resistance connection for the amp ground or you will get heating there (resistance + current = heat).
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
03-06-2023, 11:18 AM | #9 |
Excellent, thank you for the instructions!! I like the idea of a grounding washer, so I'll either get one of those, or hit the area with a little sandpaper. And I'll switch those wires around too so the ground wire is on the bottom.
03-09-2023, 02:21 PM | #10 |
Drives: 2021 SS 1LE SHOCK Join Date: Mar 2021
You need to take a grinder and get down to bare metal. Any resistance on the ground just reduces the amount of power available to the amp.
Just to throw out a random number, if the connection is 1ohm, then you are dropping a volt for every amp you are trying to deliver. Huge power loss especially for a sub amp! You can also have ground loops that will increase noise/hum. |
03-09-2023, 02:25 PM | #11 | |
