01-02-2017, 08:54 AM | #1 |
Drives: 2016 Camaro SS 6 speed manual Join Date: Dec 2016
2016 camaro ss 6 speed break in fluid change
How many qts does the 6 speed transmission require?
01-06-2017, 03:03 PM | #2 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
01-06-2017, 03:37 PM | #3 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
I see amsoil finally got the 2016 camaro specs in. That is cool. Thank you for sharing have been waiting for that.
01-06-2017, 04:42 PM | #4 |
Thanks for the update
01-06-2017, 06:16 PM | #5 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
FYI there is no "break in" fluid swap needed on this manual transmission. Why do you feel the need to change it? Even Tremec says it's not necessary.
01-06-2017, 07:36 PM | #6 |
Perfectionist I picked up from my grandfather I guess. I grew up with nothing so every vehicle I've purchased since I was 14 years old I have babied.
01-06-2017, 07:54 PM | #7 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
I love that!
Kindness and compassion #OthersFirst |
01-08-2017, 03:35 PM | #8 |
Drives: 2017 Camaro SS Join Date: Aug 2016
To be honest, with most diff/transmission problems people are reporting, GM's first port of call always seems to be change the fluid... preemptively changing all the fluids at 1000 miles or so might not actually be that bad of an idea before the problems develop in the first place.
01-08-2017, 03:46 PM | #9 | |
マスタング = 遅い
01-09-2017, 01:52 AM | #10 | |
Should the vehicle be used for racing or competitive driving (after break-in), the rear axle lubricant must be replaced before hand. |
01-09-2017, 06:07 AM | #11 | |
マスタング = 遅い
01-09-2017, 06:34 AM | #12 | |
May as well swap out the DOT 3 to DOT 4 while we are at it. |
01-09-2017, 08:20 AM | #13 |
マスタング = 遅い
The brake fluid is DOT 4, I can't think of a car that came with DOT 3 in it in years. If you are thinking better performing fluid, you just want a fluid with a higher temp rating like what Motul would make. Just remember that those high temp rated fluids can get more moisture in them and therefore require changes much more often then fluid with regular temp ratings.
01-09-2017, 12:01 PM | #14 | |
Recommended Fluids, Lubricants, and Parts Hydraulic Brake/Clutch System DOT 3 Hydraulic Brake Fluid (GM Part No. 19299818, in Canada 19299819). |
