03-21-2022, 12:39 PM | #15 |
Thanks
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
03-23-2022, 01:18 PM | #16 |
Drives: E91 BMW, Victory CCT Ness Join Date: Mar 2022
What is everyone's opinion on the GM CAI? Would you buy again?
Thanks, Jan
2022 LT1 VOM, Coupe, Manual, Recaro, NPP, Sunroof, Bose, Lowering Suspension, Sway Bar Upgrade, 6 Piston Brembo, Black Strut Tower, Front Splitter, Rear Spoiler, Sport Alloy Pedals, Hash Marks, Performance Center Caps -BMNN93
03/18/22 - 2000 03/23/22 - 3000 04/01/22 - 3400 04/18/22 - 3400 TPW 05/11/22 - 3800 - 1G1FE1R78N0127533 06/15/22 - Car picked up! 10/10/22 - All LPO's finally installed |
03-23-2022, 06:05 PM | #17 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
03-23-2022, 08:08 PM | #18 | |
(Yes, I had it and I switched to the Roto-Fab that was cheaper and looks better IMO, although it doesn't add a whole lot of power either, in all honesty.)
03-23-2022, 09:07 PM | #19 |
Drives: 2019 1SS M6 Join Date: Feb 2020
I'd buy it again.. Engine sounds much different on acceleration.. I've added the velossa tech as well.. Nice combo together...
1st Gen ground effects kit GBA black , GM CAI , Velossa Ram Air, Expel PPF, illuminated door sills, Upgraded door panels with spectrum lighting
03-23-2022, 10:23 PM | #20 |
Anyone know the correct GM part number for a '22 2SS 6.2l? I can't seem to find it anywhere.
03-24-2022, 01:21 AM | #21 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
Same set up here. You will not be disappointed.
03-24-2022, 07:35 AM | #22 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
Same part number as '20 or before, hasn't changed.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
03-24-2022, 08:25 AM | #23 |
Thanks. Everyplace I’ve checked so far says it is no longer available for purchase. Sent from my iPhone using Tapatalk
03-24-2022, 08:31 AM | #24 |
Huh, just took a look and even playing the year game it seems its discontinued. I imagine GM saw the writing on the wall after 2020.
03-24-2022, 10:09 PM | #25 | |
K&N BLACKHAWK COLD AIR INTAKE SYSTEM? K&N TYPHOON COLD AIR INTAKE SYSTEM ? K&N Series 69 Typhoon Cold Air Intake? ROTO-FAB COLD AIR INTAKE? ? ?
03-24-2022, 11:25 PM | #26 |
Drives: 2024 Black ZL1, M6 Join Date: Mar 2014
You can no longer order the GM CAI. It requires a tune and GM will NOT provide that to the dealer. I have researched this enough and spent hours on phone with GM becaue I had to remove it from my ‘22 2SS/1LE order to get my order accepted. Cold Air Inductions produces the GM one. They are the same. The tube internally is a bit different so that is why you don’t need a tube with the GM one, but performance is the same! It’s also cheaper. Only other thing is the CAI one you do not have the C.A.R.B cert for smog but if you don’t live in a state that requires it no big deal. If you do just take the 15 minutes to put stock one back on when going to get smogged. I’m putting the CAI one on next week. I had it shipped to my buddy in Vegas since they won’t ship to CA.
03-24-2022, 11:40 PM | #27 | |
So if CAI makes the GM one and the GM requires a tune does the CAI require one also? Sent from my iPhone using Tapatalk
03-24-2022, 11:47 PM | #28 | |
Drives: 2023 2SS Convertible Join Date: May 2009
-Geoff
