03-06-2016, 03:03 PM | #15 |
Drives: '16 Red hot M6 Join Date: Apr 2014
wow there's definitely more to keeping our cars looking beautiful than i thought and i definitely want to try out all these products you guys mentioned.
@Nor Cal Zl1 and Glen e , i am new to detailing my car and keeping her swirl free so i will gladly take you up on that offer to ask you guys questions when needed annnnd for my first question what do you guys think about ceramic coating? are there any cons? |
03-06-2016, 03:05 PM | #16 | |
what exactly is a touchless? i dont think ive seen one around here |
03-06-2016, 03:22 PM | #17 |
Drives: 2016 Camaro SS Join Date: Jan 2016
Touchless is the equivalent of an automated pressure washer. Nothing but soap and water touch the vehicle. They work decently enough but the soap is not particularly gentle to whatever protection you may have applied prior. It beats using the regular car washes as far as swirls and scratches go.
03-06-2016, 04:03 PM | #18 | |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
Coatings are the most durable of the protections available. Properly cared for they last years. They add a layer that is above the clear coat, and will take most of the wash induced swirls instead of the clear coat. They are also hydrophobic, and much more resistant to dirt and things sticking to the surface to begin with. That said they are easier to keep clean, and wash etc. The pro's would be durability, ease of cleanliness. With most coatings it is best to use products designed by the same manufacturer, to prep, and perform the after care. If you decide on a coating this reduces the need to collect way too may supplies and some of work to discover what works. Believe me there are about a million cool products, its a real black hole when you jump off into it with no direction, everyone of them has a standout product. Coatings are a time saver, but if you end up liking detailing they don't play well with many products so more or less once its applied you just wash it, and use a dedicated coating topping every few months. Cons would be it can be more difficult to apply, although I have found the Kamikaze line to be easy and virtually fool proof. The paint does need to be polished and properly prepped before installing a coating. It is also more expensive, but if your sticking with a particular brand it is not as bad as collecting the next best great thing and your supplies would be simple and few. You may also consider having a professional install the coating, and them properly take care of it yourself. Properly taking care of any finish at a minimum is using the two bucket wash, or two bucket rinseless wash. Top quality clean microfibers and wash media. The proper soap for the applied protection LSP (last step product). If your new to all of this you need to decide how far to take it and ask a lot of questions, otherwise your going to end up with a $1000 or more in products, but in reality use about $200 of them, One of the best ways I found to limit this was to stick with one product line, system. But if I look into my garage I failed miserably with my own advice. Here is a thread about the Kamikaze products on my ZL1. Keeping a paint job looking sharp really boils down to proper polishing and washing methods. Be sure to check my att link for better pics of the Kamikaze coating but here is a couple of primer shots. http://www.camaro5.com/forums/showthread.php?t=435906 Last edited by Nor Cal ZL1; 03-06-2016 at 04:17 PM. |
03-06-2016, 04:04 PM | #19 | ||
I used to be Dragoneye...
I know the soaps aren't great, but the only reason I really use it is for the undercarriage spray and to get the salt scum off on above-freezing days. |
03-06-2016, 04:05 PM | #20 |
Retired from Car mfrs....
Nor cal, thanks, nothing i need to add!
03-06-2016, 04:29 PM | #21 | |
the main reason i would get the ceramic coating is to protect the car against rock chips and random scratches but i would also love the perks that come with it like making the car shinier and making it easier to wash and swirls of course. i spoke with some one at a car shop and he told me the price to get clear BRA on parts of the car would run me about the same as getting the whole car ceramic coated. thats the main reason i was leaning towards the coating instead. and thats a very beaitiful zl1, thats pretty much i would like my cars paint to look forever |
03-06-2016, 04:30 PM | #22 |
Coatings protect against marring and some microscratching, but they won't stop a rock or a scratch at all. You need film for that. Search XPEL.
03-06-2016, 04:35 PM | #23 |
No problem, be sure to add any input if you think of something different, or have some other tricks to offer up. Be sure guys, to read through Glen's write ups linked in his signature. There is some great stuff in there as well.
03-06-2016, 04:42 PM | #24 | |
Also note that the proper sequence should be polish the area's before installing the film, install the film, and then coat the car. Most coatings are too slick for the film to stick to. Also insure that the coating can be applied to the film, as some can, and some can't. If the coating can't be applied to the film, Blackfire crystal seal works very well over the film. |
03-06-2016, 05:04 PM | #25 | |
Porter cable polisher with lake county orange and white pads. Menzerna FG400 for the initial polishing/swirl removal. Orange pads. Blackfire SRC finishing polish. White pads. Gyeon prep spray to prep the paint for coating Kamikaze Miaybi coat After care Gyeon Bathe + Kamikaze overcoat Added bonus of Kamikaze infinity wax... probably a little OCD... not needed. Here are product links in order of the above. In any case if you DIY you need the polisher see link. http://www.autogeek.net/porter-cable...value-kit.html Menzerna polish fantastic product. http://www.autogeek.net/menzerna-fast-gloss-fg400.html Blackfire finishing polish http://www.autogeek.net/blackfire-sr...ng-polish.html Kamikaze Miyabi pro kit. includes prep spray, coating, applicators, overcoat coating topper. From there you just need soap. http://www.esotericcarcare.com/kamikaze-miyabi-pro-kit/ Soap http://www.esotericcarcare.com/gyeon-q2-bathe-plus/ You also need two buckets and top quality microfibers, along with proper microfiber car products. http://www.esotericcarcare.com/complete-wash-kit/ This is just an example of where I am at money wise on my set up, although I have a bunch of conventional products that I am using up on my company vehicle. For me the time saved surpassed the investment. |
03-06-2016, 05:13 PM | #26 | |
03-06-2016, 05:23 PM | #27 | |
now these items look legit unlike the ones from pep boys it definitely works on your red zl1 so i will give this a try when it gets warmer. how often do you go back and start from the very beginning? and also what do you use to prevent rock chips ? |
03-06-2016, 05:47 PM | #28 |
Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
Ok come on it was not bad here today. I washed mine. It was cool but no wind. fill your bucket with warm water.
