05-20-2022, 05:33 PM | #29 | |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
It's a basic principle that a properly designed suspension itself, the shocks, struts, springs, swaybars, etc should be the only thing providing flex or compliance in a fully tunable or even dynamic way to "keep the wheels planted and avoid bounce" How do you tune/adjust the effect of a stamped suspension arm? Doing this with unpredictable flexy/bendy pieces of stamped steel is not strategic. And stamped steel does not cost more than cast or machined billet aluminum or steel. |
05-20-2022, 05:47 PM | #30 | |
Drives: HBM ZLE Join Date: Aug 2017
05-20-2022, 05:49 PM | #31 | ||
Drives: 2018 ZL-1 Join Date: Jan 2018
Fortunately for us Camaro owners, the suspension arms are one of those things where many can choose to keep them stock, and others of us can upgrade fairly easily and in a straightforward way with stiffer suspension components. But let's not pretend that the stock suspension arms are anything other than cheap stamped steel, with lots of bend and flex, that are detrimental to handling. If you want to see those bendy steel arms flex, look at this video: |
05-20-2022, 06:20 PM | #32 | ||
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
05-20-2022, 06:43 PM | #33 | |
05-20-2022, 07:03 PM | #34 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
BMR here, it rubs on my hood. maybe 1/16th x 3/4" long on both sides. didnt know it or hear it, just see the rubs on the hood now.
05-20-2022, 09:07 PM | #35 | |||
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
This is a fair question and in my opinion the right one. I'm pretty sure that the experts at GM had the proper data models to calculate deflection rates in the alloy that was chosen for the project. If I had to make an educated guess they probably had predetermined tolerances and deflection rates calculated before choosing the final design Quote:
By no means is the car perfect and it's not my intention to imply that it is the 'end all - be all'. I am saying that I would be careful before swapping out any chassis component randomly in expectation that it will make an improvement to an otherwise world class machine. This isn't your typical SS where you can throw the BMR stuff at it and transform the ride from good to great. Just my humble $0.02 Last edited by NG329; 05-20-2022 at 09:22 PM. |
05-20-2022, 09:16 PM | #36 | ||
I've seen this video and it really doesn't prove anything other than the metal bends when you put a bar to it. Unless a GM engineer chimes in and explains why they designed the part that way then it's anybody's guess at the moment. Stiffer does not always equal better and most tracks are not smoothe. You do not want to increase stiffness on uneven/rough surfaces. You need compliance. Adding additional stiffness to a car that is already stiffer than most on the market (in spite of those flexy arms) might not produce the desired result -- faster lap times. This car virtually has no body roll. I personally can't imagine why anyone would pursue more stiffness. I've actually had the chance to push the car a bit (hell, I've even totaled one). The chassis can be bouncy due to the stiffness over rough roads. Adding more stiffness to the arms will just exacerbate the sensation and ultimately make you slower. |
05-21-2022, 07:07 AM | #37 |
Thanks for all the informative info, sorry I opened a
“ Can of worms “, in regards to “tower strut brace”! But when I did suspension mods on older gen Camaro’s that was one of my easiest first mods! Anyhow, 16-21 ft lbs on those bolts? Considering It’s cast aluminum towers, I’d go with lower amount But at factory, they were barely half that when I Removed them!!! |
05-21-2022, 07:50 AM | #38 | |
05-21-2022, 08:34 AM | #39 | |
05-21-2022, 10:22 AM | #40 |
Correct, I’ll re-torque them, but when I originally
Removed those 6 bolts, they were hardly tight! I’d say under 10 ft lbs! A 1/4” ratchet could’ve Loosened them! |
05-21-2022, 11:06 AM | #41 | |
If you get out of the ZL1 1LE and jump right into a Porsche GT3, the Porsche feels "softer" by comparison. It's just a more compliant platform. Having more compliance allows you to get on the power earlier coming out of most corners. Think of it this way... if you've ever raced you know that you soften suspension settings in wet weather to maintain traction. You need more compliance. Stiffer settings tend to overwhelm a machine's ability to keep the tires glued to the ground. Same in the dry..... the closer you get to the limit the more compliance you need. Lastly, Rigid setups are very unforgiving. The stiffer you make it, the less likely it will tolerate input errors. Let's also take the C8 for example. It's down 150HP, and the chassis/suspension is very soft. Yet, it's very close in laptimes to the ZL1 in most tests while running street tires and not R compound. In spite of the understeer problems it still laps fast because the soft-ish chassis is very compliant. It's well mannered when it comes to putting the power down. |
05-23-2022, 02:20 AM | #42 |
Makis
Drives: 2020 Red Hot ZL1 A10 Join Date: Apr 2019
As per BMR instructions, you should tighten the 6 x 13mm mounting bolts to 16 ft/lbs.
Mosaic black 2018 Camaro 2SS A8 (sold) |
