05-02-2017, 09:43 PM | #1 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Installed Howard's 224/234 cam (video of idle included)
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
05-02-2017, 09:48 PM | #2 |
Specs are 224/234 .612"/.638" 112+4 lsa
1 7/8 ceramic coated longtubes / 2.5" cherry bomb extreme catback Vararam no tune intake New stock AC Delco iridium plugs with Taylor race wires LS3
05-02-2017, 11:10 PM | #3 |
Drives: Red 2013 Camaro SS, Black 1980 Z28 Join Date: Jan 2015
Sounds really good man!!!
05-02-2017, 11:13 PM | #4 |
05-02-2017, 11:14 PM | #5 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Sounds wicked man!
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
05-02-2017, 11:34 PM | #6 |
"BEASTM*DE"
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
05-03-2017, 05:42 AM | #7 | |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
05-03-2017, 05:57 AM | #8 |
How much was the cam plus install if you don't mind me asking?
05-03-2017, 08:18 AM | #9 | |
05-03-2017, 08:24 AM | #10 |
Love me some Tacos
Were the springs and oil pump changed out? Curiosity mostly as I am looking at a Howards LSA cam also.
05-03-2017, 03:17 PM | #11 |
Yes I changed out the oil pump to a high presser high volume, also used luniti voodoo duel valve springs, comp hardened push rods ,c5-R timing chain ,ls2 dog bone dampener,3 bolt timing gear with new bolts , new cam retainer plate with new bolts, new GM crank bolt , new spark plugs and Taylor 409 race wires with DEI heat socks , car only has 15,000miles so I left the stock lifters and did the swap with out taking the heads off
05-03-2017, 03:22 PM | #12 |
I did the install myself at home in the driveway so no cost for labor , the cam and supporting valve train with all the extras to do it right the first time was about 2500 dollars
My tuner does free retune for life so that was no cost but could factor in an extra 500 dollars if I had not already had that covered
05-03-2017, 03:23 PM | #13 |
05-04-2017, 06:38 AM | #14 | |
