TireRack
Old 07-08-2016, 11:23 AM   #1
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Bleeding after Hurst line lock
I'm going to be installing my Hurst line lock this weekend and wanted to know if there is a better way to bleed the system after its installed?
I read one guy said he bleed at the master and did not have to touch the calipers
any one know how to properly do that process with out getting air in to the abs pump and lines
davidscamaro is offline   Reply With Quote
Old 07-08-2016, 08:41 PM   #2
davidscamaro
Anybody ?? Did I post in the wrong section again....
Old 07-08-2016, 09:12 PM   #3
RichSS2006
RichSS2006's Avatar
Drives: 2010 2SSRS
I'm getting ready to separate the clutch reservoir this weekend. I'll be using a Movtive Products pressure bleeder. I used it last weekend on a 1st gen. It went very fast, but we bleed out the whole system. I'll also be changing out the fluid to DOT4 on my 5th gen, so I'll be bleeding the complete system.
I think it's the safest way any time you open up any brake lines.
Good luck, Rich
No longer stock, but oooh so much more fun!
RichSS2006 is offline   Reply With Quote
Old 07-09-2016, 11:51 PM   #4
davidscamaro
Finished the install, pain in the ass to mount the line lock and get the lines on ,I just gravity bleed all four calipers after. Everything seems to be working great I did a little burn out to test it. Just have to wait and see if any leaks pop up
Old 08-05-2016, 02:10 PM   #5
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
I have everything to do this install as well. I have been putting it off because I figured it would be one of those, "this should take about an hour and it really takes 2 days" type of jobs. I am looking forward to the finished product though!
Lnch Mny is offline   Reply With Quote
