Old 02-24-2020, 06:10 PM   #15
Clearly_Canadian
Clearly_Canadian's Avatar
Drives: 2017 2SS Camaro
[QUOTE=RLNTLSS;10731684]I'm planning on running zero gauge from the battery to a distributor and then four gauge to both amps fused on the zero gauge and on the 4 gauge also running a distributor block minus fuses from the ground which would be a zero to two smaller 4 gauge wires that would be the grounds for the amps Will the LC i2 remote start both
I just ran an in-line fuse from the battery to the distribution block and straight to each amp. The amps are fused, so I figured this was enough.
As far as the floor sagging, it is pretty stiff. I did not re-enforce it because this set up will only be temporary. I don’t notice any sag. Even when loaded with groceries. Maybe a little. I don’t load up my trunk enough to worry too much. I really don’t like losing the trunk space from my box not to mention the weight of it. I’ll be revamping it with a custom fibreglass set up when the weather gets warmer to work outside.
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
Clearly_Canadian is offline   Reply With Quote
Old 02-25-2020, 11:09 AM   #16
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
Originally Posted by RLNTLSS View Post
I'm planning on running zero gauge from the battery to a distributor and then four gauge to both amps fused on the zero gauge and on the 4 gauge also running a distributor block minus fuses from the ground which would be a zero to two smaller 4 gauge wires that would be the grounds for the amps Will the LC i2 remote start both amps
Humm i dont know if the LC2i will start both amps it might, but depending on the amps you have if they are newer models you can use the line out of the primary amp IE the one the lc2i is turning on to run the rcas to the secondary amp imput and use the signal sensing option to turn on the second amp may be an option,,,, or you can use a micro fuse tap to use i think fuse number 56...(CHECK IN THE FUSE BOX in the rear of the car for the correct number fuse to use) for the wireless phone charging thing in the back. it is 12v switched. this would probably be the best way. the micro fuse taps are like 12 buks on amazon for 6 or so
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 02-25-2020, 02:12 PM   #17
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
Drives: 2019 /2SS LT1
I chose to change my build last minute of this morn.. going 2k skar audio and 2 x12sa sundown in a thumpsub box sealed.
2019/LT1 2SS
RLNTLSS is offline   Reply With Quote
Old 04-05-2020, 07:54 PM   #18
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Originally Posted by Booher View Post
It's been a little over 2 years and it hasnt overheated yet. Hasnt even really been too hot to touch either, no matter how hard I crank it. I'm sure the load on your amp may make a bit of a difference.
Hi, did you install a sub amp and woofer only to your system and keep the rest of the Bose 2SS stuff?
2004YZFR1 is offline   Reply With Quote
Old 04-05-2020, 08:30 PM   #19
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
The problem people are having with the bose system is there's no real way of finding a positive and negative for your amps (rca)for your high output so you get an LC2I plug that lets you siphon from the Bose audio setup without having to cut any wires well if you get a harness from subtphhumb and it's easy good to go right there you can also turn up the signal feed for the LC2I to either be a little louder than the bose or to be a little lower than the bose but the bose stereo sounds pretty good from about 2% volume25% in up to about 50%volume and then a little after 50%..... at 60 to75%audio turned up u cant really tell anything so bassy
2019/LT1 2SS
Old 04-06-2020, 01:48 AM   #20
2004YZFR1
I think that is what i'm going to do for now also. Get the ******** harness and maybe their sub box and use the amp and sub I removed from my last car. I would love to change out the dash and door speakers and put my good components in too, but that might be further down the road. Thanks for the info.
Old 04-06-2020, 03:53 AM   #21
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
The LC2i makes the install a breez
2019/LT1 2SS
Old 04-06-2020, 11:21 AM   #22
2004YZFR1
Thanks again! RLNTSS
Old 04-06-2020, 12:54 PM   #23
RLNTLSS
INTSAGRAM: Failwish
RLNTLSS's Avatar
https://www.amazon.com/AudioControl-.../dp/B00IIL0LW0
2019/LT1 2SS
Old 08-19-2020, 04:55 PM   #24
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
OLD THREAD ALERT
This is a related inquiry: I saw in a thread that the CTS/ATS have the amp and/or fuse box located behind the side covers from the factory. Now I can't find any thread that mentions it.
Has anyone heard of this or better yet, know the bracket part numbers?
