Old 02-13-2021, 02:09 PM   #15
Markoz28
Drives: 18 ZL1 nightfall grey A10
Originally Posted by SloCal View Post
Looking at multiple listings online for 450 so firmly believe used mkt price is under 400. Thanks
Mind sharing the listing of those in $450 range?
Markoz28 is offline   Reply With Quote
Old 10-01-2021, 08:56 PM   #16
SloCal
SloCal's Avatar
Drives: 2018 2SS 1LE
Originally Posted by cthompson07 View Post
The only thing I’ve found that isn’t like OEM is that if you have the blinker on, then hit the brakes, the blinker stops for a second and then restarts. You can see this in my video at around 35s.
There’s a wire that plugs into the 3rd brake light and then into both tail lights. I taped it up and routed it with the stock wires coming from the trunk lid, and then up under the insulation surrounding the trunk. Small price to have these tails without the turn signal flashing upon braking in my opinion. These also have reverse light LEDs with the resistor needed as well.
https://youtu.be/74ZmZ3GaZmc
This was super helpful. Ever figure out a resolution to the turn signal delay when braking?
2018 1LE
2nd 6th gen
SPL Toe Arms/Brembo HTC64t/Corsa NPP/Tremec MTF Fluid
SloCal is offline   Reply With Quote
Old 10-01-2021, 08:57 PM   #17
SloCal
SloCal's Avatar
You used to be able to buy each side for about $150 on eBay 1 year ago but I never did
2018 1LE
2nd 6th gen
