04-07-2020, 07:52 PM | #15 |
Drives: 2014 2SS/RS Join Date: Jan 2018
They are weights. They reduce the harmonic chatter that the pads were doing before they added them. The chatter manifests as squealing to our ears.
2014 2SS/RS LS3/M6
04-07-2020, 09:10 PM | #16 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I can tell you this; they hit the deep recessed valve stem on MRR wheels! I was told they are tuned noise/ vibration dampeners. I had to grind a little off of them. Didn’t create any problems.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
04-08-2020, 06:30 AM | #17 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
They were on my early '10 SS. When I replaced my pads at 50,000 miles
I purchased the same from GM. Never gave it another thought.
04-08-2020, 06:32 AM | #18 |
waiting at the tree
Drives: SIM 2010 2SS/RS A6 Join Date: Apr 2013
Before the "Roller Skates" my brakes squealed like a stuck pig.
Now they are nice and quiet.
2010 2SS/RS A6 ZL1 Rims
60ft 2.03 13.08 at 107.82 (4/28) 2009 Pontiac G8 3.6L the DD |
04-08-2020, 06:33 AM | #19 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
I took mine of 8 years ago when I put all drilled and slotted rotors and Hawk performance ceramic pads on my car. I've run Watkins Glen Road course at least 5 times. And plenty of braking, no noise and no problems taking them off the car.
04-08-2020, 01:01 PM | #20 | |
04-08-2020, 01:36 PM | #21 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Before that the first attempt on early production cars with Brembos was a stack of basically wheel weights on the calipers. I had to get those off when I refreshed the paint on the calipers.
04-08-2020, 01:44 PM | #22 | |
Sporting Foole
Kind of like these - not really needed with the stiff air stems on the pressure transimitters, it's just the "idea" of them. I put them on to basically mess with people anyway. |
04-08-2020, 02:53 PM | #23 |
Drives: 2015 2SS White Convertible CE/INDY Join Date: Mar 2016
Not having those would be great for those with spare tire issues where the rim doesn't fit over them. My car is a summer car so I doubt if I'll ever change my brakes.. but when I do, I'll skip on the wheel style.
+1 on them being noise reducers. joe...
ARH LTH/HFC/Legato muffler, RDP Custom Tune, K&N Blackhawk CAI, Bigworm Blackout kit, ZL1 Rims, Phantom Grills, VMAX PTB
04-08-2020, 07:01 PM | #24 |
Drives: 2010 CGM Camaro SS Join Date: Dec 2016
Crap, which mrr? I have some mrr017 coming tomorrow, assumed they fit brembos?
04-08-2020, 08:49 PM | #25 | |
Assuming you are asking about brake pads.
04-08-2020, 08:55 PM | #26 |
USA-1
266 for pads???? WTF???
https://www.camaro5.com/forums/showthread.php?t=350352 I tracked these and use them on my daily driver and they are good...
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
04-08-2020, 09:20 PM | #27 | |
04-08-2020, 09:38 PM | #28 |
USA-1
Gotcha, for next time, do it yourself if it's just the pads. It's SUPER easy, don't even have to remove the caliper. Basically two pins get pushed out, pull the old pads out, put the new ones in, push the pins back in and done!
