03-20-2017, 01:30 AM | #15 | |
Drives: T Join Date: Mar 2015
this is awesome, how big is the shot? What kind of wheel tire setup do you use? |
03-20-2017, 07:15 PM | #16 |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
Thank you. I'm running 100 shot right now. I run bogart 17" wheels with Hoosier 28X10/17 slicks on the rear and 27.5X4.5/17 front. The track was really cold and I was worried about hooking on that pass, the nitrous was time delayed out 1.9 seconds before it came on.
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
03-20-2017, 08:11 PM | #17 |
ANGRY Z
Nitrous outlet did an awesome job on the blower lid.
03-20-2017, 10:23 PM | #18 | |
Drives: 2010 2SS/RS Join Date: May 2010
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
03-21-2017, 11:14 PM | #19 |
Drives: Chevy SS Join Date: Dec 2015
Wow, they did a great job, that looks fantastic. I was wondering how you were getting an even distribution with the feed in the rear. Awesome setup man!!!
03-22-2017, 07:40 AM | #20 |
ANGRY Z
Thank you. I've got the nitrous controlled by LPE's progressive controller. It works absolutely perfect.
03-22-2017, 07:47 AM | #21 |
Drives: 2014 SIM 2SS Join Date: Sep 2015
Heartbeat owners - what made you decide to go with this supercharger over Whipple?
03-22-2017, 08:37 AM | #22 |
ANGRY Z
I liked the look of the Heartbeat and it fit under my strut tower brace. It's a little less displacement but more than enough for my setup. I run a 9.55 lower and a 2.95 upper. Blower turns to about 21000rpm at 6500 and produces 16.5psi boost on my 396ci engine with ported TFS 255 heads,BTR3 cam and 1 7/8 headers with 3" corsa exhaust.
03-22-2017, 09:32 PM | #23 |
Drives: 2011ss/rs camaro Join Date: Sep 2011
I read,read,and read some more...in the Florida heat the heartbeat nudged the others out. So far it's everything I thought it would be,and more.
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
03-23-2017, 10:20 AM | #24 |
I run the same controller with my heartbeat. How big of a shot do you spray?
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80 “1360 Rwhp 1225 Rwtq 25 lbs of boost” |
03-23-2017, 10:58 AM | #25 | |
03-23-2017, 11:12 AM | #26 |
ANGRY Z
Just 100 for now. I'm pulling the fuel off my regulator so im hesitant to go much bigger. The spray bars are good for 400. Lol😬
03-23-2017, 11:14 AM | #27 |
ANGRY Z
I've got some logs but just on nitrous so IAT2's weren't an issue.
03-23-2017, 04:40 PM | #28 | |
It will be a while before I add forced induction to my car, but I'm definitely interested in the Heartbeat. Everyone says it's better, #s of how much better would be great to see. |
