04-03-2015, 07:12 AM | #29 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
Excellent suggestion. I obviously did it the hard way. I wanted to inspect the cam before I pulled the heads. I guess I could have done that and then put it back in for safety. I thought the lifters would just pull right out when I had the heads off, but the dowel rod had tension on them, so I just winged it.
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
04-03-2015, 12:42 PM | #30 | |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
Finished diagnosing last night, process of elimination, its a dead lifter. Ordered parts this morning, hopefully have the heads off easter to see if the cam took any damage. Yeah, I did an LS3 conversion, so I had to take the heads off and all that. This will be way easier, considering I dont have to drop and reinstall the trans, dont have to drop the oil pan, no transmission cooler to install, trunnion upgrade, tune, etc. When I originally installed I did the ziplock bag and sharpie trick too, worked great. Funny story, LS3 and LS7 lifters are the same part. I looked into the 200$ morel drop ins, and they are the same if not worse in most builder's opinions. Apparently to get a better lifter you need to spend over 500 per set. The LS7's have been used so much, that I still have faith in them. I either had a defective lifter, defective comp cam, or the lifter died from too much spring pressure, I know it was all installed correctly, and it wasnt an oil problem. Im getting new springs, .660 instead of .750. Gaskets, lifters and a new lifter tray in case the bad lifter turned. From the sound, and looking at the cam lobes I can see with the valley cover off, Im pretty sure only one lifter failed, so I just got one lifter tray instead of 4. Plan is to check the cam with a dial indicator, see if any of the lobes are off in that respect. Then ill visually inspect them and turn the cam over a few times in each lifter passage with the lifters out to see if theres any damage. Im hoping I caught it early enough to not have cam damage. If it does, Ill pull the cam, and get a new Cam Motion cam instead of Comp. If it doesnt, Ill put the new lifters in, throw the heads back on and be running by wednesday or thurs of next week. If I have to wait for a cam, itll be next weekend. Thanks for the video, it helped reinforce my diagnosis! Im an accountant and its tax season so this sucks ass, I have maybe an hour per night to work on it, and no weekend at all. If this happened on apr 16th, I could wrap it up in a day. |
04-08-2015, 12:06 PM | #31 |
I got my car back and running again last weekend! Finally had a chance to get the front back on, buttoned up and did a local test run before taking it to work today. I guess I will be babying it a while until confidence in my work sets in.
I ultimately conducted the following: Brian Tooley trunnion upgrade - super easy new Cam Motion cam - same custom grind from Spartan Brian Tooley Titanium sprint set - .660 LS9 head gaskets - made in Germany ARP head bolts LS7 lifters New lifter trays Lightly Shaved heads Cleaned heads Re-seated the valves with lapping tool and grinding compound New oil and anti-freeze other misc I wound up pulling the engine out too which is not needed for a lifter swap, but I ashamedly dropped a lifter in the engine when trying to pull it out while pulling on the dowel rod to release pressure on it. But I took it as an opportunity to paint some parts while I had it out (no pics - sorry, but red oil pan, black engine mounts and valve covers and yellow on two front areas below the heads and black water pump and timing chain cover using all high temp engine enamel) and it sure made it easy tightening down that darn oil pickup tube bolt! I gained some cool new tools along the way (some big ones). I used the torque app and my little $12 bluetooth ODBII plugin for when the engine cranked the first time to review all critical system components. I will admit when it cranked the first time, the belt squeaked (needed cleaning) and I nearly had a heart-attack right there before shutting it off. I used an engine leveler (http://www.summitracing.com/parts/SUM-G1021/) when pulling out the engine (through the top) and BOY what a difference it made getting it out and mating it back up! I also wanted provide a special thanks to Bob at Cam Motion for helping to analyze my cam shaft. Since this car was already professionally cammed and I used the same specs, I didn't have to worry about a lot of things most people do the first time around like pushrod length, PTV clearance (although I still verified it), tune, UDP, other arp bolts, oil pump upgrade and timing chain, etc.
04-08-2015, 12:45 PM | #32 |
[COTW 5/12/14]
Sounds good man, glad you got it all back together. I did the same thing, babied it for a while until I had confidence in my work, then made a few 1/4 passes and hit 11's, awesome feeling knowing you put it together yourself.
04-08-2015, 07:29 PM | #33 |
Thanks! Good luck with yours too. Not sure how lucky u are going to be with the cam though. Tax season is only a few more days, so hopefully it slows down after the 15th. Congrats on 11's btw.
04-09-2015, 01:40 AM | #34 |
Drives: 13' 1LE Join Date: Apr 2012
You have serious balls running the same lifters again...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
04-22-2015, 07:43 PM | #35 |
Counting down the days...
Drives: Black 2011 2SS/RS Join Date: Mar 2011
Good to hear you got your cam issue straightened out SeaCompiler! Hope everything goes well for you from here out buddy.
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
04-22-2015, 10:02 PM | #36 |
Thanks for the followup! Running great and learned a lot (was able to show my son a few things too). He had fun running the lapping tool re-seating the valves. Get that energy out! Had to work inside that day - too cold out.
04-23-2015, 10:04 AM | #37 |
That's awesome ^^^
