01-27-2020, 10:19 AM | #1 |
Drives: 2017 Mosaic Black SS Join Date: Jul 2018
Denting TSP headers
So this weekend I installed the Texas spees headers in my driveway and mannnn it was not fun at all, the fitment was tight.
I have having rubbing issues with the steering column even after a low profile bolt was installed. It actuall rubbs on the bolt head and on the opposing "threaded nut" side of the shaft aswell. the rubbing is not bad but enough to notice resistance. Does anyone have a solution for this? My plan is to dent/dimple the header slightly but i do not want to go through the hassle of removing and re-installing the headers. Can i do this while its installed? If so, what is the best way? Any help is appreciated! Thanks |
01-27-2020, 10:48 AM | #2 |
You’d want to heat it when denting. I think u want to do that off the car. Mark the spot with a marker.
01-27-2020, 11:41 AM | #3 |
Drives: 2016 SS Join Date: Oct 2019
I've done it before, and I'd definitely want to do it off the car. When I did it I heated it up real good and used a 2x4 on the tube and hit the 2x4 with a hammer. It looked like it was made that way, not some backyard fix, which it TOTALLY was!!!
Good luck! Is there anyway you could grind/clearance the bolt enough to make it work? |
01-27-2020, 01:16 PM | #4 |
Drives: 2016 Hyper Blue 2SS Join Date: Feb 2016
I need to do this to mine. It rubs when i'm doing hard right turns.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune Upcoming Mods: |
01-27-2020, 03:52 PM | #5 |
I had the same issue, only rub in hard right turns on the track. I also have swaintech white lightning coating on my headers so denting the header tube was not an option as this is 22mil ceramic coating. I was able to get a dremmel and grind down the "threaded nut" side of the shaft and now no more rubbing.
2017 Camaro SS 1LE
Pray ported TB/IM TSP 1 7/8 Long tube headers w catted con pipes Taylor plug wires Mishimoto oil cooler Elite X2 catch can |
01-27-2020, 08:01 PM | #6 | |
01-28-2020, 08:44 AM | #7 |
We use a marker or a paint marker to make marks around the contact points. Remove the headers and pound them down. We usually use a large metal pipe/breaker bar and hit it with a 5lb sledge hammer. It works pretty good.
Did you install 2" TSP headers? We usually notice contact points by the steering shaft and another one near frame by the flange of the headers. On the passenger side they are usually okay but there is a wiring harness that should be relocated or heat shielded. We usually zip tie it up a bit higher and then put heat shield tape over the brake line that sits behind it. |
01-28-2020, 10:09 AM | #8 |
Dyno Show Queen LOL
If you have a torch not a Home depot bottle to flux/soldier pipes.. and if the area is small I would heat the spot red hot and use a pry bar nothing sharp it will bend super easy. That's just me I work with metal a lot in my field mark it and take it off would work just as well.
Last time I saw these headers it was close to starter to.. If it was me I would get some room there to for heat issues hot starters no likey to crank..
01-28-2020, 10:19 AM | #9 |
Drives: 2016 Camaro SS Join Date: Sep 2018
We just used a dremel and ground the piece down enough to where it wasn't making contact anymore. Kind of a pain in the ass to do but worked without having to remove and dent the header.
01-28-2020, 10:21 AM | #10 | |
Dyno Show Queen LOL
That works to!
01-28-2020, 12:11 PM | #11 | |
I used carbide bits used for metal/wood. It is a little tight down there but much easier than taking headers off for sure
2017 Camaro SS 1LE
01-28-2020, 09:57 PM | #12 |
Thanks for the info! I have the cordless Dremel so it makes thing easier. I amazon primed the bits.. will update this weekend
12-26-2022, 07:11 AM | #13 | |
Drives: 2018 camaro ss1 Join Date: Nov 2018
12-26-2022, 07:12 AM | #14 | |
