09-01-2022, 08:54 PM | #1 |
Drives: 21 ZL1 Join Date: Feb 2022
Best bang for buck mods for power?
Lets hear what you are using and how its effected your traps/ETs and measured HP.
I would assume everyone does a rotofab at first. But all I feel is a bit more blower whine. I'd like to pick up a few tenths and a few MPH over stock. Whats next? |
09-01-2022, 10:14 PM | #2 |
PKG4U
I’m still stock… from what I have gathered your next step if you were taking it step by step could be a solid e85 tune. I’m assuming this question is ignoring a warranty.
Also I’m no tuner but I get a weird feeling our cars work better with like e50-60 but I could be wrong. Something about injectors blah blah idk someone with a better explanation will chime in soon enough
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S Mods after Warranty “Imma keep it stock” |
09-01-2022, 10:16 PM | #3 | |
But for full E you need many parts as well correct? Like injectors and fuel pump and whatnot? |
09-01-2022, 10:57 PM | #4 |
PKG4U
Like I said you might get mixed answers, but I know you can do it on stock parts. I guess at that point you will have some debating reliability etc, but if you get tuned properly and have the proper kit I don’t think you necessarily have to have pump and injectors, but I’m no expert. It’s late so some of the more Knowledgeable will have chimed in by the morning.
09-02-2022, 05:37 AM | #5 |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I would call JRE for his 125 package. I believe the single best value mod would be a flexfuel kit and tune... but logic says if you are going to tune, you would want to make the most of that investment also, so a solid phase 1 mod plan would be a JRE 125 package or similar (headers, rotofab, flexfuel)
Simply put, to get the best value of a tune, save for as many bolt-ons as you can at once... hope that helps.
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
09-02-2022, 05:43 AM | #6 |
Drives: 2017 ZL1 Join Date: Jan 2017
2650
09-02-2022, 06:06 AM | #7 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Nitrous.
09-02-2022, 07:05 AM | #8 |
2SS ickle
Drives: 2022 ZL1 1LE, 2022 2SS 1LE Join Date: Mar 2022
Soliciting opinions about the best choice between these parts:
1. Magnuson vs. Whipple...? 2. Kooks vs. ARH vs Stainless Works...? 3. Roto Fab vs. AFE ...? Ease of install, Ease to adapt to platform, Best quality, Best price vs. quality,
2022 2SS 1LE / Vivid Orange A10 (delivered 10/08/22)
2022 Lexus ES350 F Perf, white/red/black leather 2022 F150 Lariat Sport Rapid Red 2022 ZL1 black/black, MT, (SOLD) 2023 C8 Corvette, 2LT / Amplify Orange, Z51(SOLD) ********** |
09-02-2022, 07:36 AM | #9 | |
Thank you Al Oppenheiser!
Best bang for the buck: driver mod. After that: deweight. Hint: front seats. Then: flex fuel & tune. |
09-02-2022, 07:44 AM | #10 |
Flex sensor and tune. Should be able to run around E70 otherwise stock
Next set of mods would be, ported supercharger, headers, rotofab, 103tb. Should still be able to run E50. Next step from here is fuel system and pulley. We are running E60 with +30 injectors, LPE hpfp, jms, with a 2.17 pulley making 14 psi on a Kong standard port. I would also look at ToohighPSI port injection setup. Last step Heads/cam...and if this step is in your plans skip the ported supercharger and go to a bigger unit.
2016 NFG 1SS A8
09-02-2022, 08:44 AM | #11 | |
Petro-sexual
Maggie 2650:
RE: Rotofab Just go Rotofab. I'm sure the other CAIs are just fine. I don't think you'll find anyone that would complain about their RF. Quality, fit & finish, design, value, etc., are all top notch, and with a BG - you'll need a racecar, essentially, if you want to max' that thing out. I think the post about JRE's package is a good one to consider, too. He was testing from the start, and getting great improvements, with pretty much ZERO downsides to anything else. Same kind of boost, so no increase in MATs, and opening up the front and back of the engine just made it more efficient with the hardware GM gave us. With some E', you can take the fueling to it's limits, but get all the benefits, with very little downsides. If this were a package I could run, I probably would've gone this way, with a ported blower. I think that would have put me at the power goal I set. I think this package would allow the car to be completely happy for as long as there's fuel to power it.
09-02-2022, 09:20 AM | #12 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
People can talk all day about the mods that can be done.
The real answer is what is YOUR goal and how much are you willing to spend. FYI, any CAI is not going to gain you anything but extra whine from the supercharger and even then. A CAI for the ZL1 isn't really needed until around 700 or 750 rwhp. The stock airbox is very efficient. |
09-02-2022, 09:35 AM | #13 | |
As for removing weight, I might do the passenger seat and rear seat. |
09-02-2022, 09:37 AM | #14 | |
Drives: Chevrolet Camaro ZL1 1LE Join Date: Oct 2021
