10-31-2020, 11:15 PM | #1 |
Drives: 2010 Camaro 2SS Join Date: Mar 2018
exhaust cutouts flaps
is this the correct way and position the electronic flaps go the left for the driver and right for passenger?
11-01-2020, 06:48 AM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
That is correct. The picture they provide is the exact same way.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
11-01-2020, 07:51 PM | #3 |
Pipe
Do I start the cut shown in the second picture to leave enough to insert the pipe? 2 1/4
11-01-2020, 08:11 PM | #4 |
Yes, cut the upper line on the top picture so you have enough pipe to slide the sleeve of the cutout over.
11-02-2020, 01:58 PM | #5 |
Finally got them installed ,wow they have such a deep growl
11-02-2020, 02:20 PM | #6 |
Don't forget to put some of their low profile turn downs on there so it directs the exhaust more toward the ground. And just wait til you cam your car and headers !! Nice job!!
11-02-2020, 02:30 PM | #7 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Very nice job. I have the toggle switch but am going to get rid of it and put the Billet Button in. It comes in 6 available colors. If interested. www.keepitcleanwiring.com
11-02-2020, 05:30 PM | #8 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
Those just 2.5”? Where’d you get them from?
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
11-02-2020, 06:07 PM | #9 |
Ill eventually get some of these I think but I want the remote so I dont have to wire a switch into the car. There is already one switch in the cup holder for the interior lights.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
11-02-2020, 06:43 PM | #10 |
Ordered them directly from quicktime performance the shipping was super fast got them the second day.
11-02-2020, 08:03 PM | #11 |
I think there is a way to wire them into the overhead garage door opener buttons (Homelink) if you have that package from the factory.
11-03-2020, 08:38 AM | #12 |
Now that would be cool also. I do happen to have that in my car and only use one of the three buttons.
11-03-2020, 12:30 PM | #13 |
I think that set is called their "aggressor" kit...
11-04-2020, 10:00 PM | #14 |
does this also need a gasket or just metal on metal?
