09-08-2019, 09:23 PM | #43 |
Drives: like an old lady Join Date: Jun 2012
myth or not i am doing it. i know several local guys with different engines who lost them due to saturation.
09-09-2019, 10:39 AM | #44 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Here ya go... Tadge answered: Great question, Patman. This is one I bet a lot of people are curious about. Obviously, maintaining the quantity and quality of the oil in your engine is paramount for long term durability and performance. There are many things that work to deteriorate the quality of your oil and we make the oil life monitor (OLM) as accurate as we can to predict oil life in consideration of all of those variables. The simplest variable is the length of time the oil is in the engine. As you surmise in your question, this is an important variable. Oil ages sitting inside your engine differently than in a sealed container. It is exposed to more oxygen, humidity, various sealants and a variety of metals in your engine. Also, time causes things you might not expect to have an influence such as oxidation of your oil filter. To account for this variable there is an OLM clock that begins a year-long count down every time it is reset. So that is the best you can do…. Change your oil and filter once a year. You also surmise that mileage should be a factor. We could use mileage, but it is more accurate to actually count combustion events. Every time the fuel and oxygen ignite in the cylinder a tiny quantity of contaminants slip past the piston rings and gets into your oil. Over time, these contaminants build up and hurt the oil’s lubrication capability. You can see this effect as the oil darkens over time. OK, but all combustion events are not created equal, right? There is a big difference between cruising down the highway under light load and tearing it up on the track. On the highway, the coolant and oil stay relatively cool and there is little stress on the engine. On the track, when oil temps are high, oil molecules actually fracture and that hurts lubrication performance. We handle that buy adding a multiplier that compounds the number of combustion events that occur at higher temperatures. The hotter the oil, the more heavily we weight those events and the shorter the life prediction. On the other hand, running your engine at low temperatures stresses the oil as well. So we also have a multiplier that over-weights combustion events when it is cold. People who drive in cold climates and take relatively short trips are going to find they have shorter oil life. The display in the cluster is regularly updated to the lesser of the time-based or use-based metrics. Lastly, to get to the first part of your question: No, the dry-sump cars do not use the same algorithm as the wet-sump. As you theorize, having more oil dilutes contamination and distributes thermal stress across a greater quantity of oil. Those are both true and, even though you get some life extension, it is not in direct proportion to the total quantity of oil in the system. Why not? Well the time-based degradation is very insensitive to oil quantity. And don’t forget the oil in dry-sump cars get more exposure to air and system metals (and other materials) because of the tank and plumbing. The extra oil quantity helps roughly in proportion to volume for contamination, but not quite in proportion when it comes to thermal stress. Since dry-sump cars are more likely to see track duty or hard street driving we tend to be a little conservative to make sure oil is changed before it falls below a performance level needed to assure perfect operation of your engine. Bottom line is that, depending how you use your car, the dry sump will have at least the life of wet sump, and probably somewhat more.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
09-09-2019, 10:39 AM | #45 | |
Saturation of what, btw? They have data? Can you get copies to post here?
2017 HBM SS 1LE
09-09-2019, 06:07 PM | #46 |
oil saturated with ethanol. the events have happened sporadically over the last 15 years, those reports are long gone.
09-16-2019, 06:03 AM | #47 |
INTSAGRAM: Failwish
Drives: 2019 /2SS LT1 Join Date: Jun 2015
Reading through all of this...CAN YOU JUST TURN THE FLEX FUEL on in the ecu after flex fuel parts have been added... Or do you hav'ta tune for the e85..and 91octane? My tuner says u gotta tune for both.. reading through all these post here.. mention nothing about tuning..i figured it would be ideal..
2019/LT1 2SS
09-16-2019, 06:13 AM | #48 | |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
09-16-2019, 06:16 AM | #49 |
INTSAGRAM: Failwish
My bad your right..i reread this whole thing so many time..post #7 says it all.. im sorry guys for not realizing i missed..thanks for correction/ssmike
2019/LT1 2SS
