02-11-2020, 05:31 PM | #1 |
Drives: 2017 SS Convertible, Black Join Date: Feb 2020
Need a Part Number please
Friends, I just bought my second Camaro, first gen 6. I upgraded from the LT to the SS and am pretty excited about it. I bought it used and it is missing this piece. It is a plastic cap that is mirrored on the both sides of the car and is visible when the convertible top is down. I have spend quite a bit of time looking at part diagrams but have not been able to find the piece to purchase a replacement. Can anyone ID the piece/part number for me? Many thanks.
02-11-2020, 05:36 PM | #2 |
02-11-2020, 07:15 PM | #3 |
Drives: 2019 Camaro SS M6 Join Date: Jan 2020
Hi. I will try to help you. I looked your part up on gm parts now website. I put in for a 2017 Camaro SS.(Didn't know your year, but it'll be the same 16-18.) On the website navigate to Body, then sub category Interior trim convertible top, then look at item#5. I believe this to be the piece you are looking for.
Side molding Left #84171869 Right #84171870 You may also need the clip. Check it out and see what you think. I hope this helps. Last edited by Jb54; 02-11-2020 at 07:17 PM. Reason: Add |
02-11-2020, 08:23 PM | #4 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
I had those replaced under warranty on both sides. There is no part number available for just that rectangular cover; it is part of the assembly (which includes the entire cover next to the rear seats) in which it slides. The cover gets pushed open on curved tracks by the top mechanism when the top goes up. When the top opens, a coil spring (like in a tape measure) slides the cover up and back and closes the opening.
From what I understand, there was a redesign to the entire cover which added an extra clip to make it less likely to flex and break. As part of the redesign, the rear window regulators were also redesigned to accept the new clips, so the regulators must also be replaced. You didn't mention your year or warranty status. If you are under warranty, just get it fixed at a dealer. |
02-11-2020, 08:38 PM | #5 | |
Upper Quarter Trim - GM (84397869) right Upper Quarter Trim - GM (84397871) left |
02-11-2020, 08:55 PM | #6 |
Drives: 2017 Camaro 1LT Convertible Auto V6 Join Date: Jul 2017
02-12-2020, 01:34 PM | #7 |
Thank you all for your help! It is a 2017 and it is not under warranty unfortunately. I assumed it was just a plastic cover but it is sounding like it is quite a bit more involved than that.
02-12-2020, 01:40 PM | #8 |
Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
Try taking it to a dealer anyway, I just took my 2016 2SS in that is out of warranty to the dealership for an oil change, and when I dropped it off, I asked them to take a look at it, order what parts were needed, and give me a quote on what it would take to fix. When I picked my car up, they handed me the keys and told me they had the parts in stock and fixed it for no charge. I'm sure it depends on the dealership and how they feel that day, but I was fully expecting to pay for this repair and they surprised me.
02-12-2020, 01:47 PM | #9 | |
02-13-2020, 12:00 AM | #10 | |
Drives: '17 2LT/RS 2.0T M6 50th Anniv Vert Join Date: Feb 2019
Here's a link to the TSB. It shows the parts that need to be replaced. https://static.nhtsa.gov/odi/tsbs/20...39149-9999.pdf Good Luck and post up on how it turns out! |
02-13-2020, 11:30 AM | #11 | |
02-14-2020, 04:07 PM | #12 |
As an update, I went into a local dealership with the service bulletin and everyone there asked how I had a copy of it. Felt a little like I had something I wasn't supposed to have. Anyway, I got the parts department to sell me the part (which they had in stock I assume because of how common this problem is). Then I drove over to the service department and just asked one of the techs about the part. He helped me get the old piece off and get the new one fitted in right there in the parking lot. In retrospect it would have been fairly simple to do myself except for the part where he connected this little rod to the plastic flap that retracts when the top goes up. That seemed to take some know-how...but I think I would have figured it out eventually. All in all, it cost me $80 and about 20 minutes. As far as car fixes go, it was about as easy as it gets. Thanks to everyone on this forum. You guys were very helpful.
02-15-2020, 12:22 AM | #13 | |
I believe the TSB is public information, so it's not big deal that you have it. |
