Old 11-06-2017, 07:15 PM   #1
travislambert
travislambert's Avatar
Drives: '17 ZL1
Car Trailer for ZL1 1LE
I'm shopping for a car trailer to haul a ZL1 1LE back and forth to the track, and I'm looking for advice/recommendations.
I'd like to find something with 5K tandem axles that is reasonably lightweight. I'm considering lengths between 18 and 24 feet. My primary concern is being able to load the car easily without dragging the front fascia.
I've been looking at ATC's open trailer
http://www.aluminumtrailer.com/open-car-trailer
as well as the ATC Raven enclosed trailer with an escape door.
http://www.aluminumtrailer.com/raven...um-car-trailer
I plan to pull it with my 2014 GMC Sierra 1500 with a 6.2 and the max trailering package. It's rated for 11,800 pounds, but at the end of the day it's still a half-ton truck.
travislambert is offline   Reply With Quote
Old 11-06-2017, 07:37 PM   #2
dlct3
Drives: 2018 ZL1 1LE
An enclosed is great, but it will certainly not be very easy on the truck with the wind catch and all. Where we live I'd recommend more towards the open trailer for the hills, etc. I have an open trailer now with a front nose and use almost 9ft ramps on a dove tail trailer to avoid loading/unloading damage. If I were to pick up another open trailer it would be the SUNDOWNER -ULTRA (22'ft) and I believe they come with 8' ramps and have a lower deck height than some. Hope this helps.
http://www.sundownertrailer.com/tlr-ULTRA.html
dlct3 is offline   Reply With Quote
Old 11-06-2017, 07:46 PM   #3
travislambert
Drives: '17 ZL1
Thanks! That's one I didn't know about. I'll check it out!
Old 11-06-2017, 07:46 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
I'm hoping mine will fit like my 5th gen did. 18ft steel deck with Etrack for wheel straps
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 11-06-2017, 07:48 PM   #5
dlct3
I added a link. Good luck!
Old 11-06-2017, 07:50 PM   #6
Race Car
Drives: 997 2S, 991.2 GT3, ZLE 1LE
I have an ATC 18' open trailer and it tows great with my Tundra. Great trailer with the only downside being the ramps are a bit short. I need to use some wood or I scrape the front of my GT3... didn't get the front axle lift
Race Car is offline   Reply With Quote
Old 11-06-2017, 08:10 PM   #7
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Serious question I've always been curious about....why not drive the car if it's street legal?
2017 Camaro ZL1 M6 - Everything but the sunroof - Sold
2010 Camaro SS - 650RWHP Daily Driver - Traded
Infern0 is offline   Reply With Quote
Old 11-06-2017, 08:14 PM   #8
travislambert
Drives: '17 ZL1
For me, it's a 250 mile round trip to go to the track. With a lot of negative camber and soft tires it becomes pretty expensive to make that trip with the car. If something happens to the car at the track, it's nice to have a ride home too.
Having a truck to put a jack, spare tires, canopy, chairs, fuel, etc. is also nice.
Old 11-06-2017, 08:25 PM   #9
2010REDSS
2010REDSS's Avatar
Sorry, not a great pic, but here are some thoughts from a guy on his third trailer...
Open trailers are great...but fuel tanks, spares, tools all need to be stored in your truck. I started with an open trailer.
If you get an enclosed, get 24' at least. If you get into tracking you'll need the space, trust me. My second trailer was a used 20' Haulmark.
If you get an enclosed trailer, get a driver's side jump door for ingress and egress. Climbing in and out the drivers window gets old quickly. This one is a 24' and love it.
Regardless of the trailer you buy, get race ramps for loading. They make it a breeze and no scuffed splitters.
PM me if you want any other thoughts. Good luck!
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS" (Sold)
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR" (Sold)
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 11-06-2017, 08:30 PM   #10
Infern0
Bring It
Infern0's Avatar
Drives: In Between
Ah, well when you explain it like that it makes complete sense.
Old 11-06-2017, 08:32 PM   #11
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
I've been driving back and forth to the track for 4 years now...for these reasons above...I'm also looking into trailers.
Old 11-06-2017, 09:32 PM   #12
396ssrat
Drives: 66 Chevelle SS
If you guys can fit it in an enclosed you won't regret doing so.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
Old 11-06-2017, 09:40 PM   #13
YLWJKT
Drives: 2017 ZL1
I have an Aluma 8220 tilt trailer with a stone guard..
I use a set of 6' Race Ramps and have no issues.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
YLWJKT is offline   Reply With Quote
Old 11-06-2017, 10:05 PM   #14
Tachitup
Tachitup's Avatar
Drives: 2020 ZL1 1LE M6; previous 2018 ZL1
I have a 16' Aluma open trailer with custom 11' ramps that store under the trailer. The deck is 16" above the ground. I pull it behind a Saab 97X aero with a 6 litre. It hauls down the highway at 75 mph up and down hills. I've no problem storing tools, tires and refreshments in my truck, My empty trailer weights under 1200 lbs, has 3500 lb axles.
My recommendations:
1/ Stay small and light;
2/ Get long ramps so you don't need to carry extra wood or rubber extensions;
3/ Brakes on two axles;
4/ Buy and extra wheel and tire for that one day when you need it.
Good luck,
Tachitup is offline   Reply With Quote
