12-05-2021, 11:24 PM | #1 |
NPP 3-way switch
While looking at fuel system videos, I ran across this video that explains using a 3 way switch to control NPP.
The idea is to have the valves fully open, fully closed or controlled by the ECM/factory selector. Isn’t this basically the same as changing the settings in the FSCM? If it is the same, was there no way to control the valves on the 5th gens? https://m.youtube.com/watch?v=R1WfpAotXIY
12-06-2021, 07:42 AM | #2 |
Drives: 2018 Camaro SS vert Join Date: Oct 2020
So this guy just made his own mild2wild setup?
In case you aren't familiar with it the setup is pretty much a remote controlled fuse puller https://www.mild2wildexhaust.com/
12-06-2021, 11:53 AM | #3 |
Drives: 2019 Chevrolet Camaro Join Date: Mar 2020
I just used HP tuners to program my NPP valves.
12-06-2021, 03:25 PM | #4 | |
I agree with what you said and just change this in HPT.
