09-26-2021, 10:00 PM | #15 |
Drives: 2019 ZL1 Join Date: Mar 2019
HAHA you say that now.... Well talk again in 6 months
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-26-2021, 10:07 PM | #16 | |
Which Interchiller you going with? FI You'll be able to run max timing with the chiller so you'll be maxing out your fuel system close to 700.
09-26-2021, 10:11 PM | #17 |
Ok, that sounds about right.
'20 ZL1 1LE A10,
09-27-2021, 01:57 AM | #18 |
Drives: CMaro Join Date: Sep 2018
09-27-2021, 02:30 AM | #19 |
Drives: '17 ZL1 M6 Join Date: Apr 2021
100% happened to me
'17 ZL1 M6
8xxwhp Magnuson 2650 |
09-27-2021, 05:57 AM | #20 |
Black lightning
[ 2021 Camaro ZLE 10 speed
09-27-2021, 12:01 PM | #21 | |
CSP sells the FI interchiller Seems like the best one available. I'm just waiting to get mine installed, it will probably be snowing though when they get me in for the install. Hurry up ALEX.. LOL
09-27-2021, 02:31 PM | #22 |
Well I think you'll be wasting money porting the 2650R. After working for Magnuson almost 2 years and racing for them for almost 4 years I think you'll find there are no gains on the Lt1 or Lt4 platforms. The Mopar is a different blower and not like the 2650R as far as configuration, port or head design. What works on a Mopar does not always transfer to other brands.
09-27-2021, 03:08 PM | #23 | |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
09-27-2021, 03:44 PM | #24 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
I only wanted 700whp maybe a little more. With a 2650, 103mm tb, 5" intake, headers/x pipe, low side fuel pump I got right at 700. Fuel was maxed out.
Porting seems like overkill unless you're really going for that 1kwhp+ goal. |
09-27-2021, 03:52 PM | #25 | |
09-27-2021, 03:58 PM | #26 |
Agreed, which is the point I was making. Some of the porting shops have found ways to get even more power out of any blower, OEM or aftermarket. It probably varies greatly based on a lot of factors as you mentioned.
09-27-2021, 04:05 PM | #27 |
for sure
09-28-2021, 05:04 PM | #28 |
Thanks for the info guys , I’ll post the results later in a week or 2 ordered my maggy like 12 weeks ago.
