10-24-2020, 11:50 AM | #43 |
Drives: '23 Hyundai Kona N, '24 VW GTI Join Date: Aug 2019
My car came with the cold air intake and I just found out that bumps me out of BS for some strange reason... So I think I am going CAM-C as well, and getting the ELSD reflash. BS and CAM-C times are very similar in my area, so it should be just as fun to compete. And the PAX bump is not too much.
10-24-2020, 03:05 PM | #44 |
Drives: 2017 SS 1LE Join Date: Mar 2017
Had mine in for track re•alignment and had them flash it. Been wanting to try autocross. Track days are fun, but looking for something you measure your improvements.
10-24-2020, 04:06 PM | #45 |
You're gonna love it. You can go full send without consequences if you screw up.
10-26-2020, 08:04 AM | #46 |
Drives: 20 SS 1LE Join Date: Jun 2020
What does this mean? One wheel peel instead of lockup? It's a diff. It can only do so much.
John Hale
multi time solo nats runner up :( |
10-26-2020, 09:03 AM | #47 |
Drives: 2020 2SS 1LE Join Date: Nov 2017
10-26-2020, 11:21 AM | #48 |
10-26-2020, 11:27 AM | #49 |
Yes, but what does it mean? How does it change the car?
John Hale
10-26-2020, 03:10 PM | #50 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
From what I know it only operates in track mode with all nannies off, and under ~90 mph.
It is faster and more aggressive as far as locking the rear diff exiting corners, from what I hear... I have not seen the actual calibration data. I plan on getting it done to my car sometime this winter, so I have not experienced it yet either.
10-26-2020, 03:59 PM | #51 |
So diff lock happens much earlier and likely at a much lower throttle application. That would make corner exits more predictable I guess. In stock form, it's like tiptoeing to the edge of grip. Just a bit too much and wheelspin takes away momentum. This cal likely just makes it reliably slidey.
John Hale
10-26-2020, 04:23 PM | #52 | |
Drives: 2013 BMW M3 Join Date: Jul 2016
https://www.camaro6.com/forums/showthread.php?t=532096 Here is the thread with all the details of Chris V's description of the before and after results with the ediff tune on the autocross course at Grissom. (5 pages) |
10-26-2020, 04:36 PM | #53 | |
I'm hoping the AX cal, camber plates and 315/18s will allow me to get near the top of Cam-C locally next year, but we'll see... there are some excellent drivers in CAM.
10-26-2020, 11:08 PM | #54 |
I just meant that he was going to enjoy doing Autocross. If you push too hard on the track, you could roll the thing up into a little ball. A big autocross mistake usually just means you rub out a little cone rubber the next time you wash the car. So you can push the car quite a bit more without risk.
10-27-2020, 05:25 AM | #55 |
Ditto funked1. I believe it will also benefit in learning to improve in a safe manner. You can push yourself a bit more and overall improve your skills and have some fun.
10-27-2020, 07:44 AM | #56 | |
Drives: 22 1SS 1LE Summit White Join Date: Sep 2016
#53 F Street
2022 Sponsor autocrossdigits.com Autocrossing Videos https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag Instagram: apexit_53 2022 Rapid Blue 1SS 1LE 2019 D Street national champion (2019 civic Type R) |
