06-04-2015, 08:03 PM | #1 |
lost clutch at a autocross
Clutch went to the floor and could not pull it back up. I did get it to work by just starting the car in gear and then just pulled the clutch back up. Made more runs with no issue. I would not be heat related at all because it being first run and not a long one.
06-04-2015, 08:05 PM | #2 |
Drives: 82,85,88,88,89,91 Camaro,88TA,87GN Join Date: Nov 2011
are you just running the stock clutch master / slave and also just factory fluid?
06-04-2015, 08:34 PM | #3 |
I installed a spring kit from Lingenfelter because of the possible issues with this. I have heard of many C6 Z06 cars that have the dreaded "clutch pedal stuck on the floor". The return spring kit is simple to install and should prevent any possible problems with the factory return spring being less than adequate.
06-05-2015, 12:06 AM | #4 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
No issue with the ZL1....I've been to two track days so far...
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
06-05-2015, 12:16 AM | #5 |
Drives: 2011 Boxster Spyder (best car ever) Join Date: Aug 2014
Simple fix, do my track day flush......1.5l of Castrol SRF and A mity vac........change it all out in 30 minutes
06-05-2015, 06:17 AM | #6 | |
KaBoom1701
And yes, what backeddy said also...you need to bleed the brake fluid from the reservoir before and after each track event as well.
Mods:
06-05-2015, 11:41 AM | #7 |
Jumanji
Drives: '14 Z/28 - AGM - No A/C Join Date: Mar 2014
06-05-2015, 11:45 AM | #8 |
Drives: Chevys at the limit Join Date: Nov 2010
As stated, change out your fluid and that will help a ton.
Best regards, Tyler 888-308-6007 |
06-05-2015, 01:29 PM | #9 | |
Drives: 14 Z/28 0# Join Date: May 2013
I had the same issue but mine gave little warnings long before the pedal went to the floor. Still do not know what it was but I suspect the oem fluid boiled in the clutch since we bled and put in srf in but failed to bleed the clutch at the same time.
"PTM11" Search & Destroy
06-05-2015, 05:05 PM | #10 | |
KaBoom1701
I believe so....I'm almost 99.9% positive they share the same clutch pedal and reservoir set up. Quote:
You may be right buy it's a small thing to do to prevent this. Having your clutch not return when high performance track event would not be fun. A split second distraction can mean your into the wall ASAP depending on the course your on. Just my .02
Mods:
06-06-2015, 04:34 AM | #11 | |
Drives: '16 C7 Z51 Join Date: May 2012
Replacing fluid often is helps quite a bit. Also, not that I claim OP has done it, but no launches with semi-engaged clutch on these cars, please : )
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
06-06-2015, 07:13 AM | #12 | |
06-06-2015, 10:08 AM | #13 |
the correct answer is "all of the above". read this:
http://www.superchevy.com/how-to/eng...ally-speaking/
06-06-2015, 01:01 PM | #14 |
interesting. thanks for the link stephen
