03-19-2020, 12:40 PM | #1 |
Drives: 2016 2SS M6 Mosaic Blk Met-SOLD Join Date: Jun 2016
New, bigger battery. Big difference.
I have had the "starter heat soak" issue or whatever the problem is, where the motor struggles to turn over when hot.
I just installed an Optima yellow top with 800 cc amps. It was $300. The difference just in cold start up is significant. Motor turns over immediately and smoothly. With my old battery, it took 2-3 seconds cranking and sounded labored. I am taking it out tomorrow to get it hot and see if the starter still has the heat soak starting issue.
Official Detailer of CamaroFest 8 & 9
https://www.autogeekonline.net/forum...st-8-pics.html https://www.camaro6.com/forums/showt...=521655&page=1 https://www.camaro6.com/forums/showt...=547470&page=1 https://www.camaro6.com/forums/showthread.php?t=527474 No one on Earth has detailed more Camaros. http://KirkTheDetailer.com |
03-19-2020, 01:24 PM | #2 |
Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
Let us know! Mine is the same way and I've seen people say replace the battery, replace the starter, add a ground wire, add a heat shield... I've been considering that Optima battery, I hope it helps!
03-20-2020, 09:35 AM | #3 |
Drives: 1SS Hyper Blue Metallic, MRC, NPP Join Date: Apr 2016
My starter was doing the same thing, so like you I put the biggest battery I could and the car starts a lot faster now, but living in the south my starter still gets heat soaked in the summer months and labors to start from time to time. Here is the battery that I bought - https://www.batteriesplus.com/produc...cca/sli48agmdp
03-20-2020, 08:56 PM | #4 |
Drove 600 miles round trip and it started strongly and smoothly at every stop. Ambient temps were 70-75 degrees.
03-20-2020, 11:32 PM | #5 |
2020 Shadow Gray 2SS
Kirk, would you please post the exact battery you bought?
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
03-21-2020, 08:36 AM | #6 |
04-02-2020, 02:05 AM | #7 | |
Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
04-21-2020, 02:29 AM | #8 |
Drives: SS 6 speed of course Join Date: Jan 2016
Sure that will work for a while, but the issue is the starter cooking. I wrapped my starter and put back the heat shield to.
04-21-2020, 10:43 AM | #9 |
Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
I'd keep it on the Optima trickle charger, the only way I've had long term success with Optimas.
04-28-2020, 01:10 PM | #10 |
Thanks! Got one on order.
08-11-2020, 09:14 AM | #11 |
I found my battery drain. It was the morimoto sequential tail lights.
