08-09-2014, 09:46 AM | #1 |
Drives: 2010 Camaro SS 6 speed Join Date: Mar 2014
3.91 GM Gear Kit Install Quote
GMpart 19301504 retails for $450.00, I called my local GM Service Center and got a quote of 5.5 hours shop time to install at $130.00 an hour. That's $715.00 for the install with the cost of the kit it is $1165.00. I don't mind paying for quality work I just don't want to be taken advantage of, does this quote sound reasonable for those who have had this gear kit installed,?
Some people like to stand out in the crowd to be noticed......I like to stand back in the crowd and notice people....
2010 Camaro SS LS3 SW performance Headers, SW Retro Chambered Catback, High Flow Cats, K@N CAI, Apex Catch Can, Vmax Ported Throttle Body, Hurst Short Throw Shifter, 3.91 Gears, JRE Tune and adding to the list.. |
08-09-2014, 09:48 AM | #2 |
Drives: 2011 SS Join Date: Jan 2014
That sounds right.
5-8 hours install. If you're unable to do install yourself, the dealer gives you a few mile warranty on it, 12000 iirc. So that's a plus. You'll love these gears!
2011 SS L99 - CAI, Ported TB, Air Scoop, LT and HF Cats, Borla Exhaust, Quad Tips, 3.91 gears, 1.4 lowering springs, plus some misc.
08-09-2014, 10:40 AM | #3 |
Anybody have this done on the V6 manuals ? Really thinking hard about doing this at some point
08-09-2014, 12:14 PM | #4 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
5 hours sounds good, 8 hours sounds really long.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
08-13-2014, 07:33 AM | #5 |
Drives: 2013 Black-on-Black 2SS/RS Join Date: Jan 2014
I was going to ask this question myself. Doing the swap myself is beyond my skill level so I got a quote from the dealership. Your quote is better than mine. I was quoted about $1230 after taxes.
Performance Mods: CAI intake, BBK 95mm TB, 1-7/8 SP LT Headers, Comp Cam. 466rwhp
08-13-2014, 07:47 AM | #6 |
Drives: 2010 camaro ss Join Date: Jun 2010
I was told install time was 1 or 2 hrs. They seem to have cores ready to install with the Eaton true trac. Does this sound good?
08-13-2014, 08:21 AM | #7 |
Drives: 2010 Camaro SS/RS LS3 Join Date: Apr 2013
$715.00 is a good price, my dealer quoted me $1200.00. I paid $750.00 for my install with a reflash of the computer for the gear change.
08-14-2014, 09:00 PM | #8 |
Drives: 2013 SS/RS LS3 NPP/Hurst Join Date: Oct 2012
Take it to RPM Motorsports in Garner, NC. They do outstanding work, and will quote you a much better price! They did mine and even re-calibrated the speedo for free.
08-20-2014, 03:59 PM | #9 |
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm Join Date: Feb 2009
7 hours is what the norm is out here in AZ including the recal, bet were at $95.00 per hour.
URR2SLO - If you're not going fast enough, get out the way......
08-20-2014, 07:22 PM | #10 |
I have an appointment for this Monday for my 3.91 gear install with them.
08-22-2014, 02:10 AM | #11 |
if you want to keep your GM warranty thats not a bad price. If you will be tuned. I bought all the GM parts myself and took the rear end to a gear shop. I have less then $700 into it and a 1 year warranty. labor was like $350. If you're just doing gears all you need is the gear set, a pinion bearing and pinion seal. if you want you could do carrier bearings and axle seals. Havent heard of anyone needing shims and if you do they are cheap and your installer will already have them for next to nothing as they are the same as a 8.8 ford and another common diff.
08-22-2014, 09:18 AM | #12 |
Drives: 2015 Commemorative Edition Join Date: Jul 2013
I did my 3.91 install with a qualified mechanic. Took about 5 hours and the hardest part was crushing the new crush bearing.
The install came out great and the car takes off like a rocket now (It's a V6 with an automatic). $750 labor doesn't sound bad at all. |
08-22-2014, 09:20 AM | #13 |
I would go Strange S-Track
08-25-2014, 04:40 PM | #14 |
