Old 09-30-2017, 07:56 AM   #1
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
Replica ZL1 rims
Size:  131.1 KBWheel Size
20x9.5
Wheel Offset
40
Bolt Pattern
5-120
Hub Size
67.1
Back Spacing
6.82
This is what I am wanting to run on my 17 1SS on all 4 corners plus I want to put 285/35-20's on them, what kind of issues would I run into on the front's or any where else.
warren3537 is offline   Reply With Quote
Old 09-30-2017, 10:03 AM   #2
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Too close to strut....well it would hit the strut before you could mount it
Need a 15mm spacer up front to clear.
Old 09-30-2017, 10:31 AM   #3
warren3537
warren3537's Avatar
Wouldn't I need a hub centric wheel spacer? and a 15mm spacer would be thick.
Old 09-30-2017, 10:36 AM   #4
davet435
davet
davet435's Avatar
Drives: 2016 2SS Mosaic Black
Send a message via Yahoo to davet435
What are you hoping to gain with this setup?? That tire is pretty wide for that wheel which can affect it's performance.
Replacement car ordered 2/02/2016
2/03/16 2500
2/04/16 3000 no TPW
2/8/16 3000 TPW 2/29
2/18/16 3400
3/3/16 3800
3/4/16 4B00
3/5/16 4300
3/7/16 4200!!!
davet435 is offline   Reply With Quote
Old 09-30-2017, 11:00 AM   #5
BradfordCamaro
SABIO
You are basically putting the stock rear size on the front.
You would need longer studs and a hub centric spacer.
Unless these wheels are dirt cheap.
Put that money...and the extra effort into a properly sized set of wheels.
I guess you want to rotate?
Get a 25mm offset for all 4. It will make the rear push out a little but will still be inside the fender....and look better.
275/35/20 would work well too
Old 09-30-2017, 12:16 PM   #6
warren3537
warren3537's Avatar
I like the rotate plan, I did it to my 2010 Camaro, if anything I will do the 20X10 +23 for all four corners that way I can get one set of tires that are the same size all at once.
