09-10-2020, 06:35 PM | #1 |
Drives: 2016 2SS A8 Convertible Join Date: Aug 2010
sway bar install torque specs?
I'm swapping in 1LE front and rear sway bars in to my 2016 SS. I've searched and find data ranging all over the place.
Can someone please confirm the sway bar mount nut torque? And the end link nut torque? I've ordered the Nord-Lock washers for the front end links. Anything else needed? |
09-11-2020, 10:49 AM | #2 |
be carefull dont brake off the bolts for the actual sway bay mount it happen to me not fun!!
09-11-2020, 01:38 PM | #3 | |
Was hoping someone could verify. |
09-11-2020, 09:11 PM | #4 | |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
They broke over tightening or breaking the bolt loose ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
09-12-2020, 09:32 AM | #5 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
tom, here you go
Front sway bar links: upper 89 lb-ft, lower 96 lb-ft sway bar mount 16 lb-ft Rear sway bar links, nut 32 lb-ft, bolt 43 lb-ft sway bar mount 43 lb-ft
09-12-2020, 10:36 AM | #6 |
09-12-2020, 06:20 PM | #7 |
Geoff
09-13-2020, 08:45 PM | #8 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
On initial install of my upgraded sways, one of the mounting studs for the front bar snapped off at less than 16 lb-ft. It sheared off flush and I had to drill it out. Fortunately I had a 10mm bolt of perfect length and greater strength that dropped right in. I was using a good Craftsman torque wrench so go easy when installing these!
09-14-2020, 11:54 AM | #9 |
i didnt install them afe power did and not sure who tightened them but it happened and wasnt fun
