09-06-2020, 06:52 AM | #1 |
Drives: 2019 Camaro 1SS Join Date: Apr 2019
Tracking non-1LE SS with 6 piston brake upgrade
For those that have installed the 6 piston front brakes on a SS and tracked their car, is the track deflector and splash shield that comes with the car (In the trunk) needed or is the new performance rotor shield that comes with the kit sufficient.
09-06-2020, 07:15 AM | #2 |
Drives: 2019 2SS 1LE Join Date: Aug 2019
As I understand, you now have the exact same setup as a normal 1LE, aside from slotted rotors (and maybe different pads?), so you should be fine with the air deflector & rotor rock shield you have.
Worst case is you pick up a set of OE 1LE pads for your setup & be set. |
09-06-2020, 08:02 AM | #3 | |
09-08-2020, 10:11 AM | #4 |
Drives: 2013 C6Z06 Join Date: Nov 2016
Put the little splash shield and the track cooling deflectors on. You want all the cooling you can get.
09-08-2020, 11:16 AM | #5 |
i have the track deflector kit installed and a zzp bbk 6 piston kit on my car
Thread Tools | |
