03-19-2023, 11:12 AM | #43 |
Awesome, do the shifts feel good? No issue with TQ Management now?
03-19-2023, 11:14 AM | #44 |
What did you raise your torque tables too, 800 or 1000 lbs?
03-19-2023, 11:25 AM | #45 | |
Drives: 21 Lt1 Join Date: Dec 2016
I just copied everything over from my t87 file I didn’t mess with the VTT or anything in ecm. However while logging actual engine tq and axle tq I am showing 840 ft lb in engine and 2100 ft lb on axle tq. Not sure if that helps or not? I don’t know enough about those tables to mess with them, I’m slowly learning things. . I did get my drivability to where I like it thou by tuning the driver demand tables and tq convertor psi and apply/release tables. I do feel like there could be more left in the car thou with some more tweaking.
21 Camaro LT1 Fully forged, Katech ported stock heads, P1X,3.7 upper and ATI w/ 8.25 lower, Stage 2 intercooler, Race B.O.V, Btr stage 2 blower cam, Btr Trinity intake, 103mm TB, F.I.C +30’s, Fore innovations, LPE big bore pump, Weld Lagunas Drag Pack. Circle D TC. Full Bmr upgrades, Keltrac rear shocks.
03-19-2023, 11:37 AM | #46 | |
03-19-2023, 11:48 AM | #47 | |
On another not there are 5 new tables in the T93 vs T87A Hopefully you can get some nice gains with the TCM. I’m looking fwd to seeing the results. Your car definitely works!!!
03-19-2023, 12:35 PM | #48 | |
03-19-2023, 02:17 PM | #49 | |
So I’m curious are there guys that will just tune the tcm? Although I’m sure the ecm needs tweaking with it.
03-19-2023, 03:03 PM | #50 |
My ECU is right on point right now and since I'm not changing my shift points I don't think the ECU will need touching, (maybe) just the TCM. My car shifts hard and fast so no need to change much. Main thing is TQ management so we can get rid of the issue with pulling timing on the launch and that's caused by GM limit on torque.
03-19-2023, 03:17 PM | #51 | |
Mine doesn’t pull timing on launch, I did pull 8* trying to get it to hook thou. It was spinning pretty bad 2-3 and even the 5-6 shift it got squirly on big end. Mine is pulling timing sometimes on the shifts but sometimes it’s fine. I’m gonna have to get back to the track for more testing.
03-19-2023, 08:39 PM | #52 |
This is the stock table here: I assume this is what you are referring too?
03-19-2023, 10:50 PM | #53 |
I'm guessing you'd change all those to 1000 lbs of torque. Maybe King could chime in on that one. My table looks different for my A8 C7 and 16 SS. I'll find it differently on the A10 from the looks of your table.
03-19-2023, 11:03 PM | #54 |
Drives: Chevy Camaro ZL1 Join Date: Feb 2023
edited
03-19-2023, 11:30 PM | #55 |
The table that effects throttle opening is cmd torque vs gear.
2016 NFG 1SS A8
03-20-2023, 07:26 AM | #56 |
Thx King
