03-03-2021, 01:16 PM | #1 |
Sarcasm loading --------
Will ZLE fit on uhaul trailer?
As the title says, will a ZLE fit on uhaul trailer?
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
03-03-2021, 01:45 PM | #2 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
If a non 1LE ZL1 can (because I have put my ZL1 on a Uhaul trailer once), I'm sure a 1LE ZL1 can. You'll need to remove the 2 plates towards the front (couple of nuts and bolts) and put down some 2x4s where the front tires will sit so the front will clear the front of the trailer.
Plus you'll probably need some 2x4's as a step up for the car to clear the ramps as you load it. |
03-03-2021, 02:24 PM | #3 |
Drives: '18 ZL1 1LE Join Date: May 2020
I found an older thread where u-haul trailers were part of the discussion regarding a ZLE. See link...
https://www.camaro6.com/forums/showt...=526431&page=2
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
03-03-2021, 02:39 PM | #4 |
This was the very last comment from the link I posted...
Blast2hell: Drives: 2020 ZLE Rally Green A10 Join Date: Sep 2016 Location: Orlando Posts: 173 As a follow up to the uhaul. The silver uhaul trailer is wide enough, however at the front of the trailer is a 6" tall bump stop designed for your front tire to be up against. Obviously this is a problem considering the clearance of the front splitter. You could put something down like some boards or something to raise the height of the tire up, but personally I didn't like that idea. I guess I'm going to look for a trailer this summer.
03-03-2021, 02:49 PM | #5 |
Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I bought some nice long trailer ramps from these guys years ago so I could easily load my other lowered track car onto any flatbed tow truck without scraping, an articulated flatbed can do this easy but they aren't always available when you need one...
https://www.raceramps.com/?gclid=Cj0...saAnTvEALw_wcB |
03-03-2021, 03:30 PM | #6 |
Like I mentioned. Take those 2 front plates off and add a couple of 2x4s on each side where the front tires sit. You'll need to cut them to length though and then it'll clear the front without scraping the splitter nor the rubber strip under the front.
It'll ratchet down fine with those boards in place as long as you put enough down to cover the contact area of the tires. |
03-03-2021, 04:07 PM | #7 | |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
03-03-2021, 04:49 PM | #8 |
Oh yea. Very true but I doubt the rental people would even know they were missing but I wouldn't want to test them.
03-04-2021, 12:02 AM | #9 |
Drives: 2017 ZL1 Join Date: Aug 2020
I was using a uhaul trailer often for my C5Z and got tired of the front air dam hooking over the front lip of the trailer. I took some 2x10 cutoffs from work and screwed some 3/8" plywood on top of the 2x10's after checking the dimensions at the very front and back to the round rod (something close to 13") that would drop in there semi tight and viola, works for the camaro as well.
You just have to remember to pull em out when ya return the trailer. Nowadays I drive to the track but every now and then this is cheaper then a $6k trailer and then finding a place to park it. |
03-04-2021, 09:26 AM | #10 | |
03-04-2021, 08:59 PM | #11 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
I've seen it, it's a tight squeeze!
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
03-04-2021, 09:06 PM | #12 | |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
Does anyone have pictures of there car on a u-haul. |
03-04-2021, 09:23 PM | #13 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
It will and I have done it, but it's not easy. You need fairly long ramps (I disassembled an 8X8 pallet because it was all I could find) and you have to back it on. We drove the tow vehicle over a curb onto a higher surface to decrease the approach angle and that worked.
It will not go on forward and you need to decrease the approach angle to get it on backward. Oh, and BTW.... you'll need to get out of the car on the passenger side because the right trailer fender is fixed and the door won't open. The left trailer fender is releasable on a hinge. Last edited by Dixie ZL1; 03-04-2021 at 09:34 PM. |
03-05-2021, 10:00 AM | #14 | ||
I don't have any pictures but you can search for that trailer online and see what it looks like. Pretty basic but it does the job. I purchased a set of race ramps and use a couple long pieces of 2x6's to help the car get onto the trailer. If you find a dove tail trailer, then race ramps would be the only thing you'd need. Quote:
I've driven the ZL1 onto a Uhaul trailer twice and had no problems with it going forward other than needing to raise the loading ramps to more of an angle like you mentioned. |
