12-20-2012, 05:47 PM | #1 |
Yes, another fitment question!
Simple enough, will these rub the fenders or wheel liners? The tire section width in this is the same as the tires I want. Thanks.
12-21-2012, 05:00 PM | #2 |
Nobody?
12-21-2012, 05:54 PM | #3 |
Drives: 11 Seconds or Faster Join Date: May 2012
The fronts are the sime size as the stock rear, good to go. From my calcs, you shold be good on the rears, but don't come after me if they aren't
12-21-2012, 05:58 PM | #4 |
I know Pedders runs 10.5 on all 4.... BUT I think you should be good with that setup. May want someone else to chime in that actually has the wheel/tire size you want.
My Mod Journal <-- Its updated... again!
12-21-2012, 07:48 PM | #5 |
12-23-2012, 10:50 PM | #6 |
Drives: Rally Yellow Camaro+Avalanche Join Date: Dec 2009
If you can, go with 10 front and 11 rear. I see you're looking at 315 rear tires which has an optimal rim width of 11".
There are a lot of vendors now offering this setup. I recommend Forgeline, they make an awesome set of light weight and strong wheels in all sorts of patterns.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump. CTS-V 6 pistons.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM |
