View Poll Results: What fuel system do I need for 570 whp? | |||
Stay stock and tune up! | 5 | 5.56% | |
Use 60lb injectors included with turbo kit and install a ZL1 pump | 31 | 34.44% | |
Get bigger injectors with ZL1 pump | 39 | 43.33% | |
Get bigger injectors, BAP and ZL1 pump | 15 | 16.67% | |
Voters: 90. You may not vote on this poll |
Thread Tools |
04-22-2012, 01:38 PM | #15 |
Drives: 2010 Camaro 2SS/RS Join Date: Sep 2009
If you truly are going to stay at 570-600 rwhp then 60lb(@ 3 bar - 43.5psi) injectors are plenty so you just need more flow from the fuel pump(ZL1, dual etc.). But, the problem is you will end up getting used to the new found power and want to push it more that is just how it goes.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock 2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo |
04-22-2012, 01:54 PM | #16 |
Drives: 10 IOM 1SS Join Date: Feb 2010
Nice post, dont mean to jack it, but I am actually going to have the Turbonetics kit installed in the upcoming week on my 2010 1SS manual. I am also installing a cam kit with mine. I am going to run about 8lbs to keep it just under 600hp with the tune. I am running stock everything else, injectors, fuel pump etc.
I was wondering if this is going to be safe for the engine right now. I know if I plan on going up in LBS and HP, I will then i have to start upgrading other things like the pump injectors, and so on. But for right now will my engine be safe still using the other stock parts? thanks |
04-22-2012, 02:29 PM | #17 | |
04-23-2012, 07:23 AM | #18 |
Fuel pressure is 70 PSI on the ZR-1
www.jannettyracing.com
04-23-2012, 10:36 AM | #19 |
need....more....hp
Drives: The Neighbor Hater Join Date: Dec 2010
I ran ID-850s back when I was supercharged and made 620whp. we added a KB BAP and had no issues with fuel.
Mast Motorsports Built LS3 Stroker 418, IPS GT35R Twin Turbos, Exedy GTO4XD Twin Disc Clutch, Aeromotive A1000 Eliminator Stealth Fuel Pump, AEM Meth Injection, DSS 1400hp Axels, BC Coilovers, Pfadt & BMR Suspension, Hawk HPS Pads, Drilled/Slotted Rotors, Hurst Shifter, Custom Roll Cage by Blu808, T3 Ports, 22" Custom Concave Mesh Rims |
04-23-2012, 11:20 AM | #20 |
04-25-2012, 08:49 PM | #21 |
It looks like the majority says zl1 pump and id-850s then?
04-26-2012, 10:27 AM | #22 |
need....more....hp
Ya, ID850s should be fine, but you might want to turn up the boost in the future so it might not hurt to spend the little extra money and get ID1000s so you wont have to address the injectors again.
04-26-2012, 11:07 AM | #23 | |
Ted.
04-27-2012, 09:25 AM | #24 |
04-27-2012, 11:02 AM | #25 |
It depends on Fuel pressure and BSFC of the engine but over 1k pretty easy.
04-27-2012, 12:04 PM | #26 |
110 lb per hour at 58 psi,
Enough for 1400 Crank HP
04-27-2012, 12:15 PM | #27 | |
Time for the XX-trim Blower or the Twin YSIs http://www.vortechsuperchargers.com/product.php?p=11 http://bangshift.com/wp-content/uplo...s1-685x685.jpg
04-27-2012, 03:59 PM | #28 |
how much for the twin ? and how much rwhp can u expect?
