02-17-2021, 12:44 PM | #15 |
Drives: 2019 Camaro 1SS A10 Join Date: Nov 2015
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6 2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD** 2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD* 2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD* |
02-17-2021, 12:45 PM | #16 |
Driven oil response
DRIVEN OIL was kind enough to respond:
Hello and thanks for your email! I agree with Blackstone, the reported TBN is at the low range. Based on the amount of calcium present in the used oil analysis you were at the point of needing to change the oil, which appears to be 5,000 miles. I noticed in your email you mention that you have been running E-85 but the Blackstone report has Unleaded Gasoline. I would suspect the acidic condition that has depleted the TBN of the oil may be based on the use of e85. The oil did not go acidic per say, however it was exposed to high levels of more acidic by-products probably from running E85. That’s one of the things we may encounter with biofuels in general. In actuality the TBN did it’s job – but the 5,000 mile interval was the true maximum point of effectiveness. I was surprised as well but we need another sample to establish any sort of trend. The viscosity is good and the fuel dilution looks OK as well – so I would really like to see the next sample. Based on the wear metals I would suggest a shorter interval for your next oil change. This will get some of the particulates out of the engine and you will be past the wear in phase. We can then look at the TBN retention sooner in your drain interval (without the wear contamination). Thanks! Please send me a copy of the next sample so we can continue.
02-17-2021, 01:29 PM | #17 |
If what Driven said is true regarding E85, then I'm not sure I understand why that I ran E85 in my 5.0 with their oil and didn't have a problem.
02-17-2021, 06:28 PM | #18 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I run E85 100% of the time I have been since about 30 or 40k and I'm at almost 100k now. My iron spiked up to 55 with my first analysis after I installed my cam and heads, I just sent my last oil sample out so we will see if the levels are increasing or not. Before my cam my iron and wear metals were very low and I still was running E85.
02-18-2021, 08:03 AM | #19 | |
02-23-2021, 01:00 AM | #20 | |
Thank you Al Oppenheiser!
Your catch can will fill with water and light hydrocarbon condensates very quickly in the winter (like weekly if your trips are frequent and short). E85 adds to this. Chocolate milk shake appearance is normal in the winter. Will be darker in the summer as higher temps cause water to evaporate/burn off. Analysis shows no water in the oil so your CC is doing its job. |
02-23-2021, 07:51 AM | #21 | |
Again though, its odd that I did not have this issue with my 5.0. And my drive cycles were the same, Driven oil and same change interval.
Thread Tools | |
