03-14-2020, 11:59 AM | #1 |
Drives: 2017 ZL1 Join Date: Jul 2017
Lingenfelter Direct Injection High Flow Fuel Pump Check Valve
Just a couple of quick questions. I understand that the factory check valve can be a restriction point.
1. Where is the factory check valve located? 2. What is required to bypass it? The installation of the LPE check valve is straight forward, so no help needed there. Thanks |
03-15-2020, 02:10 PM | #2 |
Drives: 2017 zl1 camaro Join Date: Feb 2019
We even called them directly and they couldn’t answer where the stock zl1 check valve is located. Lol I have my blower off now and it’s no where up top I know that.
9.52@143 first bolt on only car to reach 9.50s. First zl1 in the 9s on stock unported blower. Sbe LME heads gptuning cam typical mods jokerz prototype port blower 9.30@150 best so far work in progress. 4.70 60-130 at 3800da now in Tennessee.
03-15-2020, 02:25 PM | #3 |
Drives: 18 Z1E - 18 Raptor - 17 Jeep SRT Join Date: Dec 2019
Follow the braided fuel line behind the charger you'll see a silver clamp on the braid, the check valve is held in place by that clamp. I just installed the lpe valve this weekend. I cut the factory hose to see what the check valve looked like and I was amazed how damn small it was.
03-15-2020, 05:45 PM | #4 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
Please post your findings. I purchased a Russell 650603 in-line check valve and haven’t installed it yet. I suspect it may provide some LPFP headroom.
I couldn’t justify the LPE price, so I didn’t the $40 Russel’s AN6 with another $20 in fittings |
03-15-2020, 06:36 PM | #5 |
Does the Russell check valve neck down internally to smaller than AN6? Just wondering if an AN8 or AN10 check is the way to go, if that is the case.
03-15-2020, 07:17 PM | #6 |
The internals of the lpe are not like a standard check valve. I should have taken a pic but slipped my mind.
03-15-2020, 09:48 PM | #7 |
NOXQCES ZL1
03-15-2020, 09:54 PM | #8 | |
If someone does get a good look at the LPE check’s internals, that would be interesting to see too.
03-15-2020, 09:58 PM | #9 |
NOXQCES ZL1
That stock check valve has to be a flow restriction.
03-16-2020, 02:43 PM | #10 |
Dyno Show Queen LOL
Uwe O. with XDI (what katech sales) explained that his setup fixed this problem.
Sorian was able to make mine, I picked up about 8psi on the lowside while using the DSX aux. LPE is a great company but, you have to know what the f$#% your doing to make there fuel system work. It's not laid out or at least it wasn't last year for me.. Basically you can't go and buy there fuel system parts with out knowing a few things if you want that advertised 900 plus on all e85 to work right. 1. Big Bore Pump (*spaced correctly and measured) 2. Cam w fue lobe of 42% (not the aftermarket 32 and 38% for a normal LT1/4 pump) 3. Ck valve fix which they have now 4. A bad ass low side return style fore or aux return style capable of 100 psi and constant 80 psi that won't drop under heavy loads 5. plus 30 or 45 injectors (these can be anyone)
05-28-2020, 09:29 PM | #11 | |
Drives: chevy camaro Join Date: May 2020
05-28-2020, 09:37 PM | #12 |
because in my case i found out the hard way, did the test drive and found out the high pressure pump is pumping only 2300 psi not 2900psi it should be
05-28-2020, 09:58 PM | #13 |
05-29-2020, 10:05 AM | #14 |
Dyno Show Queen LOL
Most of the check valve problems are noise issues that are replaced by GM. Check valve is on the low side that feeds the high side and 99% of the problem is the low side not feeding the high side that will give you low pressure as well. If your making any power with the stock lt4 stuff it needs to be 70 psi under load not falling off I got mine up to 76 with a hiflow valve and the DSX low side that combo still didn't feed the LPE big bore pump enough it needs 80 psi continuously under load with no pressure drop what so ever!
what is you low side pressure I bet anything it falls off just before the high side!
