Old 10-27-2020, 09:07 AM   #239
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I am not sure why more companies do not use Cam motion cores and components. How many valve train failures have you ever heard of with Cam motion stuff?...little to none is probably a safe answer.
The 224/230 for stock converter or the 227/233 115+5 with a 3200 stall would be my choice. It might be easier to control and take some stress off the drive line components if the torque hit was softened up and carried power out further. or maybe the Turbo is just a tad on the small side?
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 10-27-2020, 09:24 AM   #240
Choda
Drives: Turbo 6.2
Bob from cam motion was a riot to talk to.
He says if my specs worked and I liked it, use them again. He confirmed my over lap of -7.5 and said it probably drives around and idles like stock. It does.
Their 224/230 115 turbo cam is closest and would “sound like a cam” and might make more power. That cam has a over lap of -3.
The next one is the one King said. 227/233 would act even more like a ‘cammed car’ with more over lap than the pervious two.
Bob said “with the turbo cams, it doesn’t matter what the idle sounds like, all they hear is the whooo whooo when the turbo singing and you flying”
Also, news to me is the lme front cover kit with their gear and bolt allows use of any LT cam. The lme parts replace the factory parts. It’s not a custom cam bolt design.
Yes king, the turbo is on the smaller side for my Power goals.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 11-02-2020, 08:09 AM   #241
Choda
Drives: Turbo 6.2
Im on the waiting list for Katech oil pump.
Putting together a list of "Turbo" cams to bounce off my tuner. I need to order parts soon knowing its a ~4 week wait for a cam alone. I'm also trying to find untouched LT1 heads.
Old 11-10-2020, 12:54 AM   #242
Choda
Drives: Turbo 6.2
I'm finding a lot of parts are on back order but boxes are slowly showing up.
Still a bit undecided on Cam and I need to just choose one because it's like a 4 week turn around. Im also hearing there are going to be some great black Friday deals at TSP and GPI.
LME billet front cover with single timing gear.
Old 11-10-2020, 06:49 AM   #243
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Have you talked to BTR, they have a stag 1 and 2 cam for FI that work really well. I ran the stage 1 cam.
Old 11-10-2020, 08:51 AM   #244
Choda
Drives: Turbo 6.2
I just did. They offer "blower cams" but not "Turbo cams". I'll sleep at night better thinking a cam named "turbo" will do better than a "blower" one for me.
Old 11-10-2020, 10:28 AM   #245
NickyRacerBoy
Drives: 1LE
Coda Nickyracerboy here.
Bob @ Cam Motions actually called me the other day and said some guy was building killer turbo setup and wanted LLR setup (low lash roller) and look it you! SWEEEEEET!!
Guys the guy, Dave, who built Coda short block is the guy that built mine too.
Wanna hear a Cam Motions solid roller at work???
NickyRacerBoy is offline   Reply With Quote
Old 11-10-2020, 10:31 AM   #246
NickyRacerBoy
Drives: 1LE
Coda use LS3 front crank seal not LT1 on that cover.
Puta dab of grey silicone on wires that go threw cover for variable vain pump.
BTW I discounted those wires and the pump runs in full pressure all the time now.
Old 11-10-2020, 10:34 AM   #247
NickyRacerBoy
Drives: 1LE
Yeah I heard that they are working on something.
Might go dry sump.
Old 11-10-2020, 12:49 PM   #248
laynlo15
laynlo15's Avatar
Yup I agree.
Old 11-11-2020, 10:06 AM   #249
gtfoxy
Drives: '21 Wild Cherry ZL1
Yes please!
Old 11-11-2020, 10:05 PM   #250
NickyRacerBoy
Drives: 1LE
Originally Posted by gtfoxy View Post
Yes please!
Beginning of vid is warm up laps.
https://youtu.be/5mVSz1GQ_WI
Old 11-12-2020, 06:00 AM   #251
gtfoxy
7,500 Redline?
Old 11-12-2020, 09:16 AM   #252
KingLT1
KingLT1's Avatar
Man these engines sound really good when they spin upwards of 7500rpm.
2016 NFG 1SS A8
