Old 05-12-2023, 06:48 PM   #197
NZZL1
NZZL1's Avatar
Drives: 2013 BRM ZL1 Camaro M6
Originally Posted by Leo72793 View Post
Everyone involved in the buyin have the instructions in their email! i will make a forum thread specifically for the install and results once they are on the car
Leo, I am also looking forward to your instructions being posted. I was late finding this thread and missed the group buy, but have since purchased the brackets on-line.
I had purchased all the Morimoto projector, and HID and halo upgrades some time ago, and have not installed anything as yet. These brackets will be much better design in mounting than I had originally planned.
Thank you so much for sharing.
NZZL1 is offline   Reply With Quote
Old 05-12-2023, 09:42 PM   #198
rsrsrs
rsrsrs's Avatar
Drives: '11 2SS/RS M6
TY TY. Once my cars back, these are going on. I am going to wet sand and re-clear my lenses and remove the oxidation while i have the time
What grits you go with? I usually 1000, 1200, 1500, 2000, then use Chemical Guys products.
rsrsrs is offline   Reply With Quote
Old 05-13-2023, 04:12 PM   #199
Leo72793
Drives: 2011 2SS/RS
You sir LINK ME to your products for sand paper. i neeeed to gorder some.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 05-13-2023, 04:14 PM   #200
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
I see you did that while on the car? How did you protect your fiberglass front bumper cover? Did you tape it off?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 05-13-2023, 04:19 PM   #201
Leo72793
Drives: 2011 2SS/RS
EVERYONE. I have created a new thread specifically for the write up and install as this page is to be retired (nolonger a group buy)
Old 05-14-2023, 07:45 PM   #202
rsrsrs
rsrsrs's Avatar
So if you look at the pic and zoom in you'll see a scuff mark by the headlight. That was due to me not taping it off. This happened when I was first learning how to do it and didn't even think about taping. But yes to answering your question I tape the are off with about 3 layers of blue painters tape. Links below to what I use
Chemical Guys BUFX_104HEX4 BUFX_104_HEX4 Hex-Logic Light-Medium Polishing Pad, White (4.5 Inch Pad made for 4 Inch backing plates), 1 Pad Included https://a.co/d/1Xsr8Ko
Chemical Guys BUFLC_BP_D2 Flex Pro Professional Backing Plate with Drill and Dual-Action Adapters (3.5 Inch), Yellow https://a.co/d/bbOuURa
Chemical Guys BUFX_102_HEX4... https://www.amazon.com/dp/B003Z9VMX2...p_mob_ap_share
I just re-read my post you quoted and noticed I made it seem like all I did was use sandpaper to get that clear. The 1st pic is the headlight sanded and the 2nd is after using V34, 36. My bad for misleading.
Sannding products are nothing special, I just grab the sandpaper from AutoZone - 1000, 1500, 2000, P3000. After I sand I use 3products from Chemical Guys. 2 are compounds V34 and V36. I use V36 first and then finish with V34. After that for protection I use Chemical Guys Jet Seal. Apply it, let it sit for about 30mins, wipe off.
V34 on Amazon https://a.co/d/awnXazK
V36 on Amazon https://a.co/d/e483lvW
They make two other compounds V32, V38 which I also have but never used. Apparently those are for headlights that are extremely bad.
Another pic of another car I did using the same products. Left side restored right side, well, yea...
Old 05-14-2023, 09:01 PM   #203
Leo72793
Drives: 2011 2SS/RS
I have V32-V38 im going to hit mine with all of them after an oxidation removal with a decent grit of sandpaper. I need my pads to come in first. After they are nice and close to clear, i am going to fully reseal the lense with a proper clear coat with UV resistance.
Old 12-30-2023, 09:34 AM   #204
blackswan
blackswan's Avatar
Drives: 2012 2LT/RS
Really sorry to miss out but wanted to say THANK YOU!
Reserved.
Alright, Group buy in has been discussed. The minimum is 10 sets.
NOTE: These are the brackets. You would still need the Morimoto Micro D2s 5.0 projectors and bulbs/ballasts)
I have the spare headlight and it will be sent in for them for R&D . Payments will be requested by them directly. They will handle all the money on their side. If you are interested, please sign up for a slot!
Paid slots will be marked with an ** as well. The company will verify them and report back once we have all paid.
Slots:
1. Leo72793 **
2. Solders18 **
3. camguynj **
4. olblue75 **
5. rsrsrs **
6. DavoinShowerHandel **
7. SummitWhite11 **
8. camarojake **
9. SaReNi **
10. Jcool100 **
11. SamhainZ28
Group Buy in closed as of 4/24/2023
blackswan is offline   Reply With Quote
Old 12-30-2023, 10:10 AM   #205
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
You can still get the brackets but without the discount
camguynj is offline   Reply With Quote
