TireRack
Old 09-09-2015, 01:47 AM   #1
damian559
damian559's Avatar
Drives: 2015 1SS, 1LE, Recaro, NPP
Talking Help me get an extra few horsepower
My local shop is hosting a dyno day at the end of October and made a bet with my friend that I'll make 500rwhp or more. When my car was first tuned with the cam back in April it made 498rwhp on a cool morning. I had my valve springs and retainers swapped out last week and we put it on the dyno and it made 489, but this was after the car was taken for a test drive and had been idling for 15 minutes before it made a pull on the dyno. It was also over 100 degrees outside.
I know these numbers are so close to each other and don't mean much but this is just for a bet between two friends. What are a few little tips to get an extra few horsepower.
1. Should my car be cool? Warmed up for a few minutes?
2. Should I put in Chevron 91 octane and put in some octane booster?
3. Put in some unleaded race gas? 100, 101 octane?
I'm going to talk to the shop owner to see if he has any ideas also, but if you guys can help me out that'd be great.
Thanks!
2015 Summit White 1SS, 1LE, Recaros, NPP
498 RWHP 447 RWTQ (Motor)
647 RWHP 723 RWTQ (150 Shot)
12.1 @ 117 (Motor)
11.7 @ 129 (Nitrous)
Nitrous Outlet Single Nozzle Kit | Stand Alone Fuel Cell w/ C16 | Custom Grind Cam | Stainless Power 1 7/8 LT Headers | CAI Intake | ATI Super Damper | BMR Trailing Arms & Toe Links | Prothane Polyurethane Sub-frame Bushings | JDP Upper Control Arm Bushings | MT Drag Radials | Tuned by SS Motorsports
Youtube Channel:
Click Here
damian559 is offline   Reply With Quote
Old 09-09-2015, 01:56 AM   #2
Pushrod Pete
Pushrod Pete's Avatar
Drives: Camaro 1LE
how about a ported throttle body? not sure if it'll result in the extra HP you're looking for, but it can't hurt, right?
Pushrod Pete is offline   Reply With Quote
Old 09-09-2015, 07:09 AM   #3
Kings2010
Kings2010's Avatar
Drives: 2005 C6, 2013 ZL1 2020 Ram Cummins
Bag of ice on the intake manifold prior to getting on the dyno. Get it REALLY cold.
Kings2010 is offline   Reply With Quote
Old 09-09-2015, 07:35 AM   #4
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
Race gas and up the timing a few degrees.
mrvenicess is offline   Reply With Quote
Old 09-09-2015, 12:35 PM   #5
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
+1 on the VMAX ported TB if you don't have one already.
Kind regards,
-Adrian
888.308.6007
JDP Sales is offline   Reply With Quote
Old 09-09-2015, 12:38 PM   #6
JantzenOKC
JantzenOKC's Avatar
Drives: '13 2LT/RS Twin Turbo
Slide the dyno operator a 20 to fudge the dyno a bit?
3.6L Twin Turbo V6
Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension
10.75 @ 131mph
JantzenOKC is offline   Reply With Quote
Old 09-09-2015, 01:08 PM   #7
IneedAZ
IneedAZ's Avatar
Isnt that the same thing you did on your 12.1 pass?
Old 09-09-2015, 01:46 PM   #8
Badfinger
Badfinger's Avatar
Drives: 2010 2SS
JET Performance Underdrive Pulley Kits 90105
JET Performance underdrive pulley kits add 10-13 HP by reducing the drag placed on the engine to drive the accessories such as the A/C, power steering, and water pump.
Badfinger is offline   Reply With Quote
Old 09-09-2015, 01:48 PM   #9
JantzenOKC
JantzenOKC's Avatar
If that was the case it would've been an 11.9
3.6L Twin Turbo V6
10.75 @ 131mph
Old 09-09-2015, 01:53 PM   #10
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Underdrive pulley, ported throttle body, port your heads, intake manifold, etc. hell you're right on the cusp of 500rwhp, you might as well get a goody to put yourself over
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 09-09-2015, 02:08 PM   #11
c5z28
Drives: Camaro, Corvette, c10 pickup
What do you previous dyno results look like? Maybe there is something hiding in them.
Do you have a graph?
When I dynoed my car I made 500.7hp from about 5000 to 6050.. It showed me I am leaving something on top, which an intake swap helped with. With the cam I have it should have peaked around 6000, not flat lined.
c5z28 is offline   Reply With Quote
Old 09-09-2015, 02:09 PM   #12
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
Slip him a 50 and go for 600
casper sc/1ss/rs is offline   Reply With Quote
Old 09-09-2015, 02:38 PM   #13
climb-101
Drives: 2010 2ss
rotating mass makes s big differance, x2 on light weight rear tires/rims.
I know on my chevelle we picked up about 30hp by taking the belt off the front and didn't run this water pump or power steering.
another thing is run it a quart low on oil, less oil for the crank to half to run through
climb-101 is offline   Reply With Quote
Old 09-10-2015, 11:33 AM   #14
sscamaro
sscamaro's Avatar
Drives: 2010 2SS, 2017 Silverado LTZ
We need to know what you have already done to your car. Just a cam is not going to get you there. Ported throttle body doesn't give more HP. Gives better throttle response.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
sscamaro is offline   Reply With Quote
