09-08-2020, 05:35 PM | #1 |
Drives: 2018 SS Join Date: Jul 2020
Rear end noise
Have a used 2018 SS with 6k miles. Little noise which almost sounds like wheel rub from rear when cold and turning a corner.
Posi not releasing? Fluid issues? I will take it into the dealer. Just getting used to the car. Disappears when warm. Odd. |
09-08-2020, 06:13 PM | #2 |
Drives: 2018 2SS Camaro Join Date: Mar 2020
Fluid change is the required fix, common item and should be under warranty. I was told its something to do with manufacturing process contaminating the gear oil, altering the friction modifiers.
09-08-2020, 06:52 PM | #3 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
Pete is rite on the MONEY!!!! Mine did it first sharp corner in the AM and a FLUID CHANGE cured it and was covered by the Dealer
09-08-2020, 07:02 PM | #4 |
Drives: 2018 2ss redline Join Date: Sep 2019
agreed. i had to take mine back 3 times before they got it right.
would groan while turning first 3 turns in the morning & longer on cold days. |
09-08-2020, 08:36 PM | #5 |
376 cubic inches of fun
Endless discussions of this topic.
If only when cold IT"S NOT A PROBLEM. Just what LSD does. |
09-08-2020, 08:57 PM | #6 | |
Drives: 2018 Camaro 2SS Aussie version Join Date: Nov 2019
LSD Oil
They told me it would have been changed at my next service if the problem had not been noticed earlier. |
09-21-2020, 02:37 PM | #7 |
Well, tech said four flushes to get it fixed. Yikes. It’s way better now. Very slight once in a while but tech said give it a few days to the new fluid to get into the clutches. Scary though. Hope the rear end is ok now. Don’t need that bill!
09-22-2020, 09:00 AM | #8 |
I doesn't go completely away. On cold days you will still get a slight groan on the first couple turns...It's normal. If it does it all the time even when up to temp, that is not normal.
2016 NFG 1SS A8
