01-27-2019, 06:39 AM | #29 | |
Drives: Chevy Blazer Join Date: Sep 2009
Sent from my SM-G965W using Tapatalk |
01-27-2019, 07:07 AM | #30 |
You really think that adding 40mm to the width of the front tires and 30mm to the width of the rear tires has no influence on the total drag?
01-27-2019, 08:51 AM | #31 | |
It does, but not as much as the big ass spoiler. Put the same wheels and tires on an SS, and the SS will still have a higher top speed. Sent from my SM-G965W using Tapatalk |
01-28-2019, 01:49 PM | #32 | |
Drives: 2019 ZL-1 Join Date: Feb 2009
There is NO limiter set at the factory on these cars that I am aware of. V6 does have a limiter.
2012 Yukon XL Denali w/ 6.2 AWD |
01-28-2019, 08:11 PM | #33 |
Drives: 2016 2SS Convertible Join Date: Oct 2017
The ECM does have a speed limit setting, at least in the convertibles.
I have mine disabled.
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
01-29-2019, 11:58 AM | #34 |
Drives: 1994 z-28, 2017 2ss 6spd Join Date: Mar 2018
KLG, How do you access this screen?
On a scan tool, dashboard or other? |
01-30-2019, 07:45 PM | #35 |
I have an SCT X4 tuner for my Camaro.
01-31-2019, 06:54 AM | #36 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
The 'speed limiter' is a warning that is set by the driver to sound a tone if set speed is detected. It doesn't disable anything. At least that's how it worked on my 5th gens. I've always had this one turned off.
01-31-2019, 07:52 AM | #37 |
I believe thats a speed warning.....Limiter is just that.
06-19-2019, 06:42 AM | #38 |
Drives: 2017 2SS Vert Fifty Join Date: Dec 2012
I have a ss vert. I dont think it has enough power to get much past the 155.. maybe you could get it to 165 if you had enough straight road.. just my thoughts.. hit 155 last week on a "private road".
06-19-2019, 10:18 AM | #39 | |
Drives: 2018 Camaro 1SS Join Date: May 2019
2018 1SS bought it in April of this year, Ive gone 160 and 150 easily?
09-21-2020, 07:48 PM | #40 |
Took my 2020 ss a10 to 155 on a road that was closed and under construction. It was only about a mile long, so started shutting it down.
09-21-2020, 09:36 PM | #41 |
LT1_Radenso
Drives: a 2 spd water bottle Join Date: Sep 2017
All LT models (including LT1) are limited to 148-149 MPH I believe, while the SS tops out around 180 MPH.
With some exceptions, The V6-LE tops out at 155, and the SS-LE tops out at 175 MPH. ZL1 can do 198 MPH, but it loses 7 mph in maximum velocity when its a ZLE. 85% of camaro owners are never going to go this high in top speed anyway.
09-22-2020, 07:28 AM | #42 | |
Drives: Fast if no one's looking Join Date: Aug 2019
