01-06-2023, 11:46 AM | #43 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
Reminder to myself: never let the inside of my Camaro trunk get wet or even damp!
01-06-2023, 12:21 PM | #44 |
Drives: '16 2SS M6 Join Date: Aug 2019
Did you replace the wiring harness too? There has to be corrosion in the harness with as much was in the box. And it very well may have damaged some of the modules.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
01-06-2023, 01:15 PM | #45 | |
The BCM may be affected, on the report it indicates 14 faults.
2018 Camaro 2.0 LT Turbo, Conversion to ethanol E85, K&N Typhoon filter, Front Bumper and rear diffuser ZL1/1LE, LED headlights |
01-09-2023, 11:55 AM | #46 |
This is where you are going to need the service manual so that you can diagnose each code. If you have to replace the BCM, it is not 'plug and play', it has to be programed to your VIN before it will work.
David
01-09-2023, 02:16 PM | #47 | |
Cycling the ignition may clear the codes. See the thread linked below. I will look into this more. I do not think your BCM got wet, so hope it is salvageable.
https://www.corvetteforum.com/forums...trusion-2.html EDIT: Since the codes are identical to what you had before, I think they may be stored (latent) codes. I found several threads online suggesting a few cycles of start car, turn off, wait a few minutes and repeat may clear the BCM. Also, see this video. If you have this BCM in the trunk you need to check it for water damage: Last edited by ctrlz; 01-10-2023 at 11:19 AM. |
01-12-2023, 12:19 PM | #48 |
No, the BCM is not in the trunk, but under the dashboard!
01-12-2023, 12:25 PM | #49 |
Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
01-12-2023, 12:39 PM | #50 | |
I find it interesting that the fault codes identically match what was present before the new fuse box was installed. I would think some codes would clear. That seems to be the pattern from other reports online. So I wonder if there needs to be some kind of "code clearing" procedure to get a fresh start. |
01-12-2023, 01:56 PM | #51 | |
Jim G |
01-12-2023, 03:02 PM | #52 |
I think the BCM codes are not generic DTC's. These probably need a Tech2 to be cleared, or whatever the proprietary GM scan tool is these days. I had read in the corvette forum that cycling the ignition a few times can clear stored BCM codes. But I do not think a standard OBD2 scanner will be able to read or clear these.
01-12-2023, 03:43 PM | #53 | |
I have to put in a new battery, so I haven't hooked up the fuse box yet. I will keep you posted.
01-13-2023, 03:59 AM | #54 | |
02-04-2023, 01:44 PM | #55 |
After replacing the battery, I reconnected the fuse box and put in a used amp and everything worked again!
02-04-2023, 02:30 PM | #56 | |
Drives: 2022 Camaro SS 1LE Join Date: Sep 2011
Congratulations!
Mark
Sugar Land TX 2022 VOM Camaro SS 1LE |
