View Poll Results: Have you experienced unexpected power loss at low speeds with the 6th Gen ZL1? | |||
Yes, I feel there is an issue with the car's ability to take off gently and/or launch. | 104 | 64.20% | |
No, the car seems fine to me. | 26 | 16.05% | |
I do not own a 6th Gen ZL1. | 32 | 19.75% | |
Voters: 162. You may not vote on this poll |
Thread Tools |
07-08-2017, 09:48 PM | #169 | |||
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
Granted, there are no real hills here in Easter NC; certainly not like WV roads. Still, if the problem were widespread I'd expect to see some manifestation of it here too. Good luck. I hope you can nail it down soon. --Cal |
07-10-2017, 07:25 PM | #170 |
Drives: '17 ZL1 Join Date: Jul 2016
Ann from GM contacted me today. They want to put a data recorder on my car.
I'm having mixed feelings about this. I feel like they should be able to easily reproduce the problem on their end, or at a minimum use what I sent to identify the potentially problematic area of the software. (And maybe they have, but I didn't get many details in the email.) The other part of me wants to help, although I'd be really nervous about letting a dealership touch my car. The last time I had my car at the dealer it only had 200 miles on it and the guy was crawling in and out with filthy mechanic clothes... no seat covers... didn't even bother to wash the dirt and grease from his hands.... but that's a different story. Anyway, I told her it'd be awesome if one of the engineers could just bring the hardware to Camaro Fest. I'd be willing to help them gather some data, and they could probably find some volunteers to help gather data for the launching problem as well. I'll keep you guys posted. |
07-10-2017, 08:31 PM | #171 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2006
In my experience going back to the early 2000's, this is the best method for GM to record what's happening and in the cases I know of (various corvette issues) the recorder was indispensable in figuring out the problem. Understood that you don't want someone messing around with the car, but its the best option now. Good luck!
07-10-2017, 08:40 PM | #172 | |
Drives: Slow Join Date: Mar 2016
So its something that you'll have to take to a dealership and let them datalog it? Is it possible to just let them hook it up and ride with you to do the logging and then let you drive back home while they send it off for analysis? I'd probably take that deal if I were you and I think it's awesome GM is concerned enough to at least go that far in helping us. If you told this to ford they probably just tell you to go buy a dodge or GM if you aren't happy lol.
2016 Toyota 4Runner
2017 Camaro ZL1 |
07-10-2017, 08:48 PM | #173 | |
From that point, I believe I'd drive to reproduce the problem and return the recorder when finished. I guess my issue is not knowing whether they even tried to reproduce the problem on their end. If the did, and couldn't...well fair enough. In my mind though, I don't know how that'd happen. All they need to do is try to take off gently with some fine gravel under the tires and the car will nearly stall. I think speaking to one of their engineers prior to installing the recorder would help me tremendously. To be fair to Ford, their car launches fine. So would you rather have a car that just works or one that doesn't work with helpful engineers?... lol (jk) |
07-10-2017, 09:00 PM | #174 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
-Bobby
ZL1::J-E-T-S JETS JETS JETS |
07-10-2017, 09:02 PM | #175 | |
I'd rather push my zl1!!!!
2016 Toyota 4Runner
2017 Camaro ZL1 |
07-10-2017, 09:05 PM | #176 |
Drives: N/A Join Date: Jan 2016
They probably want a baseline of your configuration when this happens so they can start from there. Also, it's probably part of their process before they can spend man-hours trying to do some type of RCA to figure this out.
Modded 99 Z28 - Gone
07-10-2017, 09:05 PM | #177 |
Maybe we all should do youtube videos to show what the car is doing..........
They gotta know the Zo6's and Zl1's bog like crazy out of the hole. They want to probably see the drivability issue, not the launch issue.
07-10-2017, 09:13 PM | #178 | |
I like that you used the word "bucking". I know exactly where you're coming from. Sometimes it falls flat and sometimes it bucks. |
07-10-2017, 09:23 PM | #179 | |
I'm sure its happening to everyone, How the guys who drive the CTF cars and the Camaro Team cars don't see what we see is simply crazy to me!!
07-10-2017, 09:25 PM | #180 | ||
Hell, even the MotorTrend H2H with the GT350R shows how badly the Mustang beats the Camaro out of the hole. The M6 ZL1 vs Hellcat videos that are out there are down right embarrassing. This one comes to mind: Some fault can be put on the driver in the early races, but the last race at ~3:20 completely sums up how this car launches on the strip. The Hellcat was out what, about 3 years prior to the 6th Gen ZL1... There's no excuse for GM not one-upping them 3 years later. |
07-10-2017, 09:28 PM | #181 | |
As far as the initial take off in first gear, now that I'm aware of how the car behaves on that initial take off from the driveway, I just apply a little more throttle and come out easier on the clutch and it works just fine. Again, it was just something that I've learned to try and adapt to but it's definitely reassuring to know that it's not just my car and that GM is offering to help.
2016 Toyota 4Runner
2017 Camaro ZL1 |
07-10-2017, 09:49 PM | #182 |
Drives: 18 Black ZL1-1LE Join Date: Jun 2017
I thought I was 16 learning to drive a stick again. the bad thing is it is so random sometimes it leaves smoothly and the next light you can do virtually the same thing and it falls flat on its face and almost stalls if you don't clutch it in time. I sure hope they find a fix for this it really takes the fun factor out of driving the car.
