06-05-2020, 08:46 AM | #1 |
SNSTRSS
LT4 injectors
If I have an aftermarket cam with a 38% fuel lobe and the zl1 intake fuel pump, would changing out the injectors to lt4 ones help? Or do I need to change out the hpfp to an lt4 one, to get better flow?
2016 Black Camaro 2SS A8 NP
06-11-2020, 10:04 AM | #2 |
SNSTRSS
I'm surprised no one has any info on this.
06-11-2020, 10:13 AM | #3 |
Yes, the LT4 injectors outflow the LT1 ones. With the ZL1 in-tank and a +38% fuel lobe, the LT1 injectors will be a bottleneck. You also want the LT4 HPFP as it operates at a higher pressure, keeping your injector times under 6.0ms.
06-11-2020, 01:58 PM | #4 |
You don't need to worry about high side fueling until you are north of 600whp on E85 with NA applications.
2016 NFG 1SS A8
06-25-2020, 12:19 PM | #5 |
Drives: 2017 ss1 camaro Join Date: Apr 2015
06-25-2020, 01:44 PM | #6 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Aren’t you the guy that was whining about not getting a parts list from companies for an LT4 swap so you could price shop elsewhere?
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
06-26-2020, 09:53 AM | #7 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Spot on...
06-26-2020, 11:25 AM | #8 | |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Yes he was. Apparently his Google Foo is deficient.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
06-26-2020, 12:10 PM | #9 |
Good memory!!!
06-26-2020, 03:37 PM | #10 |
Drives: 2020 LT1 M6 Join Date: Jan 2016
Reading davispaintandbody posts always brings a smile to my face, it's even sweeter when the sponsored vendors who have had the pleasure of speaking to him chime in and elaborate on the details Davis leaves out
