02-22-2021, 03:08 PM | #589 |
02-22-2021, 03:19 PM | #590 |
Your 1LE already has a ZL-1 pump and tank, however the fuel system control module is not tuned to take advantage of the pump.
I would recommend Injector Dynamics ID1050x , a 3 bar map sensor, TR7IX plugs, MSD wires, and our JRE Fuel system control module if you want to continue to tune with SCT. I don't know what parts exactly make up the kit you have so I can't predict what power it will make. If everything is right 600 RWHP is reachable although will be right on the edge on 93 octane. Ted.
www.jannettyracing.com
02-22-2021, 04:19 PM | #591 | |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Be curious as to what Ted would say..... not sure if he'll chime in about this as it's one of those mystical demonic value things that I'm not sure anyone has solid results of hurting a motor (or as far as the many I've inquired). But I'm just one of those end users with HPTuners. I've even had some ricer guys jump in and say if you're under 280*F, you're golden.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-23-2021, 07:10 AM | #592 | |
You first have to be an engine builder and have a full understanding of all the how and why the changes made for performance will effect that strategy. We tune the main tables to find optimum spark advance under given set of conditions and the IAT tables are there to adjust the advance to compensate for the accelerated burn rate of the mixture as temps rise. People look at is as a power killer but it is not, it is there to fine tune spark advance as temps rise. As intake air temps rise the fuel burns faster, so it needs less lead to hit the target peak cylinder pressure at 15 degrees after top dead center so it can do the most work on the crank. I can talk about this subject for hours but this should give you a basic understanding. Ted.
02-23-2021, 11:32 AM | #593 | |
02-23-2021, 01:55 PM | #594 |
Drives: 2010 Camaro 2SS Join Date: May 2016
I’m not answering for ted but wouldn’t a longer burn time even with advancing the timing actually make less Hp.
I would think that there is a fine line between between to quick a burn or to long. Which is why people mix it and don’t run pure water. |
02-23-2021, 02:05 PM | #595 | |
Adjusting timing is accounting for burn rate.
03-01-2021, 03:04 PM | #596 |
NEcamaro5
Ted. quick maybe question
I have 2013 ss 1LE Long tube headers , cold air , stage 4 btr cam, upgraded oil pump , lifters , rods , Just wondering if I need to change the cam to put a Lsa super charger on. I understand there are many way better setups to choose but I’m looking for a factory look and a little more push not going crazy. Thanks in advance. |
03-01-2021, 03:21 PM | #597 | |
Fuel system upgrades and large injectors will be necessary. Contact me directly for parts and tuning. Ted.
03-03-2021, 06:51 PM | #598 |
NEcamaro5
Thanks Ted. So when it’s time.A blower cam bigger injectors and fuel system. I’m assuming the fuel pump will be ok.
03-04-2021, 06:55 AM | #599 |
With the addition of a Fuel pump voltage booster and FSCM tuning or replacement.
03-14-2021, 05:11 PM | #600 |
Drives: 2014 ZL1 Join Date: Jun 2009
Hey Ted,
How much HP increase have you guys seen on 5th gen ZL1s with your 75rwhp kit + your LSA rough idle race cam kit?
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
03-15-2021, 11:10 AM | #601 | |
So if you have 75 package your next move is our 75-125 upgrade. Then add the cam. The cam is worth anywhere from 50-150 RWHP depending on combo.
03-15-2021, 06:56 PM | #602 | |
