12-24-2015, 11:31 AM | #15 | |
Warranty is about the same for all of them, and honestly we never had to use it on any of them. They pretty much all make the same power at 6 psi boost. The Centrifugal will have a slight edge in power boost for boost due to slightly more efficient and less HP consumed to turn it. I have worked with the I-1, it is a neat concept and seems to satisfy those who have purchased it for an everyday driver. Happy Holidays Ted.
www.jannettyracing.com
12-24-2015, 11:35 AM | #16 | |
You can get a screw in cap and drill and tap a fitting in to it for the oil return. Or you can weld on a fitting for oil return in the valve cover. Either way you would want to return the oil to the valve cover. I caution you that the Holley valve cover baffling is not as good as factory valve covers and you may experience more oil in your catch can. Ted.
12-24-2015, 04:41 PM | #17 |
Drives: 2014 Camaro SS Rs Join Date: Aug 2014
So my goal is to get to 700rwhp. Its a daily driver and occasional track car. Twins are out of the question. Im looking of going single turbo or centri. What would be the most cost effective way to reach that goal? Im currently right under 500hp with nf cam, TSP full exhaust, cia. I do occasionally run a NO 150 shot which bumps to an area where I like the power. Im no guru on setting up FI kits so I do t even know where to start. TIA
12-26-2015, 09:56 AM | #18 | |
JRE Vortech upgrade kit ID-850 injectors LPE twin pump ZR-1 Map sensor TR7IX plugs With your current mods will make 700 on pump and 800 on race gas with a different pulley. I developed this combo back in 2010 and it is a solid combination we have used many times. Ted.
12-26-2015, 02:53 PM | #19 |
OMWTFYB
Drives: ZL1 Join Date: Sep 2011
Whats the diff between A&A,ECS,Paxton, Procharger, Vortech????
12-26-2015, 03:45 PM | #20 |
Drives: 2013 Camaro 2SS/RS M6 Join Date: Feb 2013
Ted, I just had a maggie installed on my ss (ls3) and the only other mods I have are ZL1 fuel pump, ADM FPCM, Vmax ported tb, stock maggie injectors and CAI intake. My ending numbers are 535 RWHP / 472 TQ (I think my tq is a bit on the low side). I want to know if you think my torque numbers should be higher or is it right were its supposed to be?
2013 Black / Black Camaro 2SS/RS M6 w/Magnuson TVS2300, ZL1 Fuelpump / ADM FPCM, NPP Exhaust, Cold Air Inductions CAI w/ Scoop, Elite Engineering Catch Can, VMAX Ported TB, OEM 1LE Front Splitter, AAC Ghosted Side Markers, Dropped on BMR Split Drop Springs Build#24869 |
12-27-2015, 08:44 PM | #21 |
Drives: 2023 Camaro SS 1LE on order Join Date: Dec 2014
I have a 2010 Camaro SS, whipple making 13lbs of boost, ls9 cam, cai, tsp long tubes and a custom tune. The issue I have is when I shift from 1-2 or 2-3 at WOT the car goes super rich as soon as I let of the clutch and mash the gas again (to the point it will fall on its face and sometimes completely shut down) . If I gradually go to WOT it does fine or if I down shift to 2 or 3 and hit it it's fine. I've been leaning towards belt slip issues for a while but others say it's my tune. What's you opinion?
2017 Camaro SS 50th anniversary, I sold it but 2010 Camaro SS, whipple, cam, full bolt ons and full exhaust made 739/656 RWHP/TQ on 93 pump gas
12-28-2015, 09:02 AM | #22 |
They all used different Head units, mounting brackets, drive systems, charge pipes, intercoolers and included parts.
Paxton and Vortech are owned by the same company and share all the parts but the head unit name tag. Ted.
12-28-2015, 09:04 AM | #23 | |
The TQ is about right for a 3.8 pulley. Ted.
12-28-2015, 09:05 AM | #24 | |
I would also have to see your tune. What injectors are you running? What tune are you running? Ted.
12-28-2015, 09:36 AM | #25 |
Ted,
Im running the 65lb injectors that came with the blower with a zl1 pump and adm fpcm. The tune is from a local shop who does mainly LS cars. I believe he uses HP tuners.
12-29-2015, 06:41 AM | #26 |
OMWTFYB
Procharger P1 or D1
I see you offer both What would you recommend with a L99 DD |
12-29-2015, 08:56 AM | #27 |
Drives: 2010 camaro ss Join Date: Jun 2010
Hey Ted I've noticed that you have done lots of the slp tvs2300. I'm just wondering what maintenance is required on these blower. Also if I add a ported throttle body and a scoop will it affect the tune? Will I need to retune? It's a l99 613 rwhp and 560 rwtq 12 psi
12-29-2015, 11:22 PM | #28 |
Drives: 2011 Camaro 2SS Join Date: Jan 2012
Stabilitrak issues
Ted,
I have an ECS 1500sl kit with a fore stage 1 kit. Currently, after going passed 3200RPM my stabilitrak goes on. I took it to the dealer and since my engine is modded they won't even mess with but did hook up the diagnostic machine (U2100) code came up. I can tell my power steering pump is going out so I just ordered the lingenfelter pump. I don't know if that will fix my issue, but can offer any suggestions on what can be causing this. Thanks in advance. |
