TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > Engine | Exhaust | Bolt-On | Drivetrain Modifications
Old 04-22-2012, 02:09 PM   #1
Redline Motorsports
Redline Motorsports's Avatar
Drives: Several...
Redline Large Capacity Cooler Tank
Well since we got rained out again for another track rental day....we pulled the ZL out of the trailer this morning and started fabrication of our larger capacity heat exchanger tank.
Unlike aftermarket supercharger systems, the ZL only utilizes the coolant that is in the front mounted heat exchanger, cooler brick (located inside the supercharger) and whatever is in the coolant lines.
Our new tank will increase the coolant reserve by about 1 gallon (but we will verify when its completed). After track testing last week, several hours on the dyno and street use, we have collected a fair amount of data to work from. As it has been discussed quite often, higher Intake Air Temps can reduce power output quite a bit. Thus far on stock boost levels the factory system seems to hold its own fairly well. However as we push the TVS1900 a bit harder, heat becomes a bigger issue.
We are installing thermocouples in the entry and exit of the system to verify that the additional reserve is a benefit at the higher power levels. Temperatures will be checked under a variety of conditions and will again back up any claim with clinical data and results. Our intake that we posted dyno results a couple weeks ago raised some eyebrows at first glance but three back to back runs at the drag strip coincided with the results.
Here are a few shots of the fabrication thus far...
Howard
Redline Motorsports is offline   Reply With Quote
Old 04-22-2012, 03:34 PM   #2
charly_rock
charly_rock's Avatar
Drives: soon => ZL1 #1512
It is very cool to follow along with you guys... keep the updates coming!!
charly_rock is offline   Reply With Quote
Old 04-22-2012, 04:04 PM   #3
Redline Motorsports
Drives: Several...
UPDATED PICTURES......
Thermocouple shown is for us to data log what the temperature is leaving the tank to the pump and into the front mounted heat exchanger.
The other will be located after the brick located in the supercharger.
Howard
Old 04-22-2012, 05:23 PM   #4
Nmbr1gmfan
Drives: Fast
This is a much needed mod.
http://www.youtube.com/watch?v=fPvVm...&feature=share
New and improved non-violation sig vid!!
Nmbr1gmfan is offline   Reply With Quote
Old 04-22-2012, 05:26 PM   #5
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
cool
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 04-22-2012, 05:53 PM   #6
Pgoldston
Drives: 1999 camaro
What pump does the ZL1 use and do you know the flow rate? Does the location offer up easy removal to be replaced by something like a meizer remote?
You can lead a horse to water but you cant force people to look at the data
Pgoldston is offline   Reply With Quote
Old 04-22-2012, 05:59 PM   #7
thespymaster
thespymaster's Avatar
Drives: C7 / ZL1 / SS / trucsk
How long before you have these ready for sale?
2014 C7 Stingray 3LT/Z51
2013 Camaro SS
2012 Camaro ZL1 - 850 HP
2015 GMC Denali 3500HD 4x4
2012 GMC Sierra 3500HD 4x4
thespymaster is offline   Reply With Quote
Old 04-22-2012, 06:02 PM   #8
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Just saw redline motorsports President on Velocity on TV.
KKreme15 is offline   Reply With Quote
Old 04-22-2012, 06:53 PM   #9
Redline Motorsports
Drives: Several...
Until we can prove that they benefit the cause we are not even considering selling one yet.
HT
Old 04-22-2012, 06:54 PM   #10
austinjames
Account Suspend...Right
austinjames's Avatar
Drives: Synergy LS & Vulcan 1600cc
How much for the cardboard one?
austinjames is offline   Reply With Quote
Old 04-22-2012, 06:59 PM   #11
htron50
htron50's Avatar
Drives: 2017 ZL1 Status "Thank You!"
HAHA... if you asked Leonardo Da Vinci for his original drawings he would have given them to you at the time. This one is priceless! My question is would the extra capacity cooler be a worthwhile endeavor for simple street driver? Not that I would alter my car, but just a curiosity.
htron50 is offline   Reply With Quote
Old 04-22-2012, 07:34 PM   #12
Redline Motorsports
Drives: Several...
Completed!
If you look closely we took care of those ugly factory hoses that drop out from under the plastic engine cover!
We also confirmed its a tick under 2 gallons of additional coolant capacity. Underneath is a quick release drain so it can be dumped quick and refilled with cold water!
Tomorrow we start to see how well it works!
HT
Old 04-22-2012, 07:50 PM   #13
htron50
htron50's Avatar
Originally Posted by Redline Motorsports View Post
Completed!
HT
Awesome work! Duplicate. Duplicate.
Old 04-22-2012, 07:59 PM   #14
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
2G's is significant. It's also great to have these with a large top fill for adding ice at the track. The GT500's have used this trick for years for the best passes since their factory cooling system isn't up to the task either.
I doubled a s/c system's capacity and the results were nothing short of worth it.
Nice job guys.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Unobtainium is offline   Reply With Quote
