01-20-2021, 02:06 AM | #1 |
Drives: 2004 Silverado, 2020 ZL1 Join Date: Oct 2016
Supercharger noise on cold start
Sometimes when I cold start my car I'll hear this sort of whirring/rubbing noise that sounds like it's coming from the supercharger and it seems to go away after 30-45 seconds. Has anyone else experienced this and if so, is it anything I should be worried about? The car seems to be running fine.
01-20-2021, 06:42 AM | #2 |
Yes mine has the same noise which sounds good to me. There’s a supercharged LT4 under your hood!
01-20-2021, 06:44 AM | #3 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
^^^Agreed^^^
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
01-20-2021, 07:52 AM | #4 | |
'20 ZL1 1LE A10,
01-20-2021, 08:17 AM | #5 |
It seems like the more miles you get on the car, the noise is noticeable. I bought mine used with less than 500 miles and in the beginning the noise wasn’t there but since I have almost 17,000 miles it’s more noticeable.
01-20-2021, 09:09 AM | #6 |
Drives: '17 ZL1 A10 Join Date: Jun 2020
All jokes aside, my '17 used to make a kind of bearing going bad sound during cold starts. Then was fine after a minute or two of running.
Thought maybe the supercharger bearings were going bad or maybe something wrong with the pulley system. After listening around in the engine bay after a few cold starts, I figured out it was a couple loose bolts on my passenger side header. Not sure why it made the sound it did, but tightened them back up and no more sound. |
01-20-2021, 11:52 AM | #7 | |
01-20-2021, 07:30 PM | #8 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
Get someone to start it with the hood up while you look and listen!
Better to be safe then sorry ! |
01-20-2021, 09:25 PM | #9 |
Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
Are you referring to this noise?
https://youtu.be/V6Mb9PRsD1Q |
01-21-2021, 03:59 PM | #10 |
01-21-2021, 05:32 PM | #11 |
That’s the sound mine is making but somewhat faint. It stops when it warms up. I still say it’s the supercharger and normal. I know and have heard supercharged engines sitting at idle whinning away so that’s why I think it’s a normal sound that they make. This is the first supercharged car I have owned and it’s definitely different sounding than a naturally aspirated engine.
01-22-2021, 08:01 PM | #12 | |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
01-22-2021, 08:19 PM | #13 | |
05-09-2021, 02:51 AM | #14 |
Drives: Camaro ZL1, Durango SRT, Mustang GT Join Date: Feb 2021
Camaro ZL1, Durango SRT, Mustang GT, Mazda Miata
