Old 11-03-2020, 09:11 AM   #15
Rodan
Rodan's Avatar
Drives: 2018 ZL1 coupe
+1 on air in the intercooler circuit.
Check out my thread here on basically the same symptoms, under nearly identical circumstances (and maybe the same track?): https://www.camaro6.com/forums/showthread.php?t=563234
Update with info starts on page 2.
Problem never resurfaced after installing the surge tank in the intercooler circuit.
Rodan is offline   Reply With Quote
Old 11-03-2020, 10:19 AM   #16
DOHCVTEC
Drives: 2018 Chevy Camaro ZL1 M6
Cool... I don't know why I haven't bought the reservoir yet. Will definitely do that... Looks like the consensus is the supercharger cooling .. so I will leave the mamo T/B, do the reservoir and see what happens.. this really spoiled my day I gotta tell you.. the car was awesome otherwise
DOHCVTEC is offline   Reply With Quote
Old 11-03-2020, 10:23 AM   #17
DOHCVTEC
Any suggestions on the reservoir? I am aware of the one made by adm, any others out there? Thanks everyone who helped
Old 11-03-2020, 10:33 AM   #18
DOHCVTEC
Yep, same thing, same track. Even same color ZL1....
Hopefully that's it!
I will report back with my findings, next track day in about a month
Thanks everyone who helped out again!
Old 11-03-2020, 10:42 AM   #19
jvandy50
jvandy50's Avatar
Drives: 18 ZL1-1LE, 10 JKU
cordes has a metal one, i'm about to be picking between these two. i have also seen another company making one, but it was like twice the cost so i forgot the name lol
jvandy50 is offline   Reply With Quote
Old 11-03-2020, 11:11 AM   #20
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Apparently, you have to either modify or, eliminate the plastic rain diverter attached to the underside of the hood with the Cordes unit so, that should be taken into consideration. Wasn't Lingenfelter supposed to be coming out with one?
Old 11-03-2020, 11:17 AM   #21
jvandy50
jvandy50's Avatar
i did not know that, thanks for the heads up.
Old 11-03-2020, 11:23 AM   #22
Rodan
Rodan's Avatar
There was a thread somewhere here where a poster put together the part numbers for most of what was in the ADM kit, and it could all be bought for under $200 if you're willing to piecemeal it from various sources.
I just went with the ADM kit since I was under time pressure with a track event coming up. The Cordes setup is nice, but more expensive, and requires the mentioned modifications. It also sits lower than the ADM, and having the surge tank as high as possible is beneficial to the self purging capability. The ADM kit was also an easy install.
Here's a thread I did on the install for reference: https://www.camaro6.com/forums/showthread.php?t=564965
Old 11-03-2020, 06:19 PM   #23
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
You mentioned there are specialized tools required to do the bleed on the factory setup. Do you know what tools those are or what the procedure entails?
2018 Camaro ZL1 1LE (Red Hot)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 11-03-2020, 06:39 PM   #24
Rodan
Rodan's Avatar
I have not seen the actual fittings personally, but my understanding is the 'tool' is a fitting that attaches to the intercooler line at either of the fittings pictured in my thread, and a container goes on top of the fitting to enable purging the air in the system. The tool opens a valve in the fitting on the intercooler line.
Some folks have been able to DIY with different types of containers and funnels, and using a 1/4" ratchet extension to depress the valve in the fitting (which works like a large schrader valve).
Old 11-03-2020, 07:55 PM   #25
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
FYI,
IAT1 = MAF temp sensor
IAT2 = Fake news, don't look at it
MAT = TMAP temp sensor in back of stock blower
It is likely you have low coolant in intercooler, when MAT gets too high it will pull timing via IAT Advance parameter. It can even make you go negative timing if severe enough (lots of exhaust noise with no grunt). You will not get any codes when this is happening.
Old 11-04-2020, 11:54 AM   #26
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
This lil guy:
https://www.dedicatedmotorsports.com...illercombo.htm
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 11-04-2020, 12:09 PM   #27
Rodan
Rodan's Avatar
Originally Posted by JonDaddy82 View Post
I'd forgotten about that one... it became available after I went through the issue.
That's definitely the cheapest solution, and allows you to DIY the factory bleed process, but it's still easier to open the lid on the ADM (or other) reservoir and check the level. The fact that so many of these LT4s have had issues from the factory indicates that it's not the greatest method of bleeding the system.
Old 11-04-2020, 05:16 PM   #28
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
in for the month update
JT Camaro is offline   Reply With Quote
down on power, loss of boost zl1, loss of power zl1, lt4 loss of power
